Regression/testing:
Are we missing any kernel config settings from 3.8 that you used?
Does your Cape still work?
Other thoughts...
Some users will build/install these from src, however anyone
interested in a quick "test-me.sh*" script which will install the new
kernel on a daily/weekly basis?
* script currently doesn't exist, but after a few beers it might...
However, I’d want to netboot it. So, I’d need some way to achieve that. If the 3.12-rcx instructions on your eewiki cover that, then I should be able to deal with that.
Now if there were a way I could use your prebuilt test images . . . that’d be even better. But I have not yet taken a look at them.
Regression/testing:
Does it come with Xenomai support?!?
And when can we expect SGX acceleration?
I'm just beginning to test SGX acceleration with the 3.8 kernel (I found
some magic sauce by talking to Jason Kridner who hooked me up with
Prabindh Sundareson). I haven't had a chance to test anything yet (just
got back from a business trip), but I've managed to compile drivers
without anything that looks like a fatal error.
Other thoughts...
If you want, I'll send you some of the local 8-bit brew:
Regression/testing:
I sense, we have a new maintainer for github.com/beagleboard/kernel
If we are going to add the Xenomai patchset, i'd feel more comfortable
if we had a developer who is using/testing/etc..
Part of the goal of that repo, is just have enough for everyone to use
and base off it (for Fedora, arch, etc..)
I can't answer that. I'm a user too like you guys, and i hate NDA's
with a passion and closed "stuff"..
Other thoughts...
Regression/testing:
If it wasn't obvious, my initial comments were meant to be
toung-in-cheek. Great work on 3.12, but I need enough out-of-tree code
I'll be stuck playing catch-up on 3.8 for a while.
I'm sure I don't know what you mean...
< me: runs and hides >
I don't think the xenomai patches should be in the defalut Beagle*
kernels. I was meaning more that xenomai just recently began working on
3.8 kernels for the ARM architecture, and work is ongoing to get 3.10
kernels working on x86. I suspect it will be a while before ARM 3.12
kernels have an easy-to-apply xenomai patch. :-/
I'm hopeing I can get the SGX drivers working on 3.8. I'm back home and
can test now, if only I could find some time...
I did hear rumors here about TI jumping from 3.2 to 3.12 kernel support
for the SGX drivers, so if that actually happens, I can probably manage
porting the xenomai stuff. At least it's open source!
Excuse my ignorance, but could you point me to an "idiots guide" for download/building this kernel. The README.md still mentions the 3.8 kernel. Is it simply a matter of RTFM plus changing 3.8 to 3.12?
David,
I just pushed an update to fix the readme file.
Thanks. I will try that
We can probably simplify a few more things in it.
Does Angstrom use zImage or uImage for the bbb in the default flasher image?
