Hi All,
I want to use 3 Hardware encoders via PRU but eQEP1 and HDMI use the same pins. Is there a way to use eQEP1 and HDMI connection together? Can you suggest me any solution to use it together?
Best Regards,
Eren
Hi All,
Best Regards,
Eren
It is impossible to use all the eQEP inputs with HDMI enabled. eQEP 0 does not conflict with hdmi, and eQEP 1 is impossible to enable without disabling the HDMI. eQEP 2 requires disabling HDMI -or- disabling eMMC.
IF I use external LCD, is it possible to use it together? but as I know, it use the same pins,right?
9 Haziran 2014 Pazartesi 03:27:40 UTC+3 tarihinde Teknoman117 yazdı:
