3rd-year ECE student starting out in embedded/firmware, looking to contribute for GSoC 2027
Hi everyone, ia third-year B.Tech student in Electronics & Communication Engineering (VLSI Design & Technology) at NSUT, Delhi. I’m interested in contributing to BeagleBoard.org and preparing for GSoC 2027.My background- Hardware side: MOSFETs, digital electronics, and some semiconductor device simulation. I co-authored a paper on CdTe solar cell simulation using SCAPS-1D. - Software side: Python, JavaScript, and web basics.I’m comfortable with Git basics. - Embedded: I’m a beginner. My C is at a basic level, and I have an Arduino Uno that I’m learning to program at register level (no Arduino library functions). **Where I’m headed** I’m leaning toward the firmware side (C, RTOS, drivers), especially Zephyr-related work, since I’ve seen several BeagleBoard GSoC projects in that area. Over the next few months I’m working on: 1. Strengthening my C (pointers, bit manipulation, structs). 2. Moving to an STM32 Nucleo board and then getting Zephyr running on it. 3. Making small contributions, starting with docs or beginner-level issues. **What I’d like to ask** - Which Zephyr-related repos or issues are beginner-friendly for someone at my stage? - Is there a recommended board or setup I should get familiar with before the ideas list is out? - Any common mistakes you’ve seen new contributors make that I should avoid
Thank You
If it has to be embedded, then for me that’s programming the PRU on the beagles, that though isn’t really powerful enough to do RTOS. If I were you I’d be very tempted to look at other Texas Instruments Launchpad, or at a RPi computer module. The Texas Instruments I like because of their level of support - that is huge. What this means is they give you the software for programming the devices, so that gives you the tool chain, and if you want to go down to the level of programming registers, then each chip has a TRM (Technical Reference Manual), that goes down to describe what you have to do at register level. The RPi community also has high level of support, but that mainly at the higher OS level - I’m not sure if there is any focus at the RTOS level.
