5.4.242-bone66: mmcblk0
U-Boot SPL 2019.04-00020-gfcef48bb (Nov 17 2023 - 01:23:30 -0800)
Trying to boot from MMC1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-00020-gfcef48bb (Nov 17 2023 - 01:23:30 -0800)
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
62 bytes read in 79 ms (0 Bytes/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.4.242-bone66 ...
9290240 bytes read in 1651 ms (5.4 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/5.4.242-bone66/am335x-boneblack.dtb ...
90476 bytes read in 165 ms (535.2 KiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait] ...
debug: [bootz 0x82000000 - 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Device Tree to 8ffe6000, end 8ffff16b ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.242-bone66 (vietduc@ubuntu) (gcc version 8.5.0 (GCC)) #1 SMP PREEMPT Fri Nov 17 02:40:53 PST 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9d000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 20 pages/cpu s52876 r8192 d20852 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 449876K/524288K available (13312K kernel code, 997K rwdata, 3372K rodata, 1024K init, 339K bss, 25260K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 41010 entries in 121 pages
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000041] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000055] OMAP clocksource: timer1 at 24000000 Hz
[    0.000730] timer_probe: no matching timers found
[    0.001044] Console: colour dummy device 80x30
[    0.001134] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.046876] pid_max: default: 32768 minimum: 301
[    0.047472] LSM: Security Framework initializing
[    0.047593] Yama: becoming mindful.
[    0.047836] AppArmor: AppArmor initialized
[    0.047854] TOMOYO Linux initialized
[    0.048044] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.048061] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.048245] *** VALIDATE tmpfs ***
[    0.049306] *** VALIDATE proc ***
[    0.049706] *** VALIDATE cgroup1 ***
[    0.049725] *** VALIDATE cgroup2 ***
[    0.049878] CPU: Testing write buffer coherency: ok
[    0.049949] CPU0: Spectre v2: using BPIALL workaround
[    0.071010] Setting up static identity map for 0x80100000 - 0x80100060
[    0.078903] rcu: Hierarchical SRCU implementation.
[    0.089706] EFI services will not be available.
[    0.094912] smp: Bringing up secondary CPUs ...
[    0.094935] smp: Brought up 1 node, 1 CPU
[    0.094947] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.094956] CPU: All CPU(s) started in SVC mode.
[    0.095971] devtmpfs: initialized
[    0.119186] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.120017] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.120053] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.124085] xor: automatically using best checksumming function   neon
[    0.124118] pinctrl core: initialized pinctrl subsystem
[    0.126140] NET: Registered protocol family 16
[    0.134276] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.181192] l3-aon-clkctrl:0000:0: failed to disable
[    0.183116] audit: initializing netlink subsys (disabled)
[    0.184817] cpuidle: using governor menu
[    0.190979] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.211165] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.247153] raid6: using algorithm neonx8 gen() 0 MB/s
[    0.247176] raid6: .... xor() 0 MB/s, rmw enabled
[    0.247186] raid6: using neon recovery algorithm
[    0.255646] edma 49000000.edma: TI EDMA DMA engine driver
[    0.259145] iommu: Default domain type: Translated
[    0.260906] SCSI subsystem initialized
[    0.261359] usbcore: registered new interface driver usbfs
[    0.261425] usbcore: registered new interface driver hub
[    0.261517] usbcore: registered new device driver usb
[    0.262669] pps_core: LinuxPPS API ver. 1 registered
[    0.262685] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.262714] PTP clock support registered
[    0.268195] NetLabel: Initializing
[    0.268215] NetLabel:  domain hash size = 128
[    0.268224] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.268323] NetLabel:  unlabeled traffic allowed by default
[    0.269410] clocksource: Switched to clocksource timer1
[    1.171605] *** VALIDATE bpf ***
[    1.172134] VFS: Disk quotas dquot_6.6.0
[    1.172288] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.172456] *** VALIDATE ramfs ***
[    1.173813] AppArmor: AppArmor Filesystem Enabled
[    1.187992] thermal_sys: Registered thermal governor 'fair_share'
[    1.188004] thermal_sys: Registered thermal governor 'bang_bang'
[    1.188027] thermal_sys: Registered thermal governor 'step_wise'
[    1.188855] NET: Registered protocol family 2
[    1.189152] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.190604] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.190691] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.190738] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.190798] TCP: Hash tables configured (established 4096 bind 4096)
[    1.190951] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.190979] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.191309] NET: Registered protocol family 1
[    1.204842] RPC: Registered named UNIX socket transport module.
[    1.204862] RPC: Registered udp transport module.
[    1.204870] RPC: Registered tcp transport module.
[    1.204878] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.204906] NET: Registered protocol family 44
[    1.206133] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.209261] Initialise system trusted keyrings
[    1.209958] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.219518] zbud: loaded
[    1.228076] NFS: Registering the id_resolver key type
[    1.228146] Key type id_resolver registered
[    1.228158] Key type id_legacy registered
[    1.228186] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.228200] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.228649] fuse: init (API version 7.31)
[    1.228884] *** VALIDATE fuse ***
[    1.228902] *** VALIDATE fuse ***
[    1.265192] Key type asymmetric registered
[    1.265219] Asymmetric key parser 'x509' registered
[    1.265308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.269740] io scheduler mq-deadline registered
[    1.275974] OMAP GPIO hardware version 0.1
[    1.309567] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    1.313309] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    1.329601] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.330813] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P9_19'
[    1.331067] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P9_20'
[    1.331083] gpio-of-helper ocp:cape-universal: ready
[    1.336649] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    1.339334] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.344228] printk: console [ttyS0] disabled
[    1.344374] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
[    2.100603] printk: console [ttyS0] enabled
[    2.109010] omap_rng 48310000.rng: Random Number Generator ver. 20
[    2.115636] random: crng init done
[    2.120227] sdhci: Secure Digital Host Controller Interface driver
[    2.126710] sdhci: Copyright(c) Pierre Ossman
[    2.132113] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    2.140939] omap_hsmmc 48060000.mmc: Got CD GPIO
[    2.198877] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    2.210923] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.219566] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.225654] mmc0: new high speed SDHC card at address 0001
[    2.245529] mmcblk0: mmc0:0001 SD16G 14.8 GiB
[    2.337287] mmc1: new high speed MMC card at address 0001
[    2.348331] mmcblk1: mmc1:0001 M62704 3.56 GiB
[    2.353592] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[    2.360209] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[    2.366739] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (245:0)
[    2.401585] blk_update_request: I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.437496] blk_update_request: I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.472413] blk_update_request: I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.482777]  mmcblk1: p1
[    2.509450] blk_update_request: I/O error, dev mmcblk0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.544303] blk_update_request: I/O error, dev mmcblk0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.555129] blk_update_request: I/O error, dev mmcblk0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.566050] blk_update_request: I/O error, dev mmcblk0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.576960] blk_update_request: I/O error, dev mmcblk0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.587293] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[    2.620915] blk_update_request: I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.656378] blk_update_request: I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    2.790599] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[    2.948011] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[    2.955339]  mmcblk0: unable to read partition table
[    2.960459] CAN device driver interface
[    3.005476] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    3.015161] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    3.024672] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    3.031169] cpsw 4a100000.ethernet: ALE Table size 1024
[    3.036652] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    3.044081] cpsw 4a100000.ethernet: Detected MACID = 34:03:de:9b:14:35
[    3.052779] usbcore: registered new interface driver smsc95xx
[    3.064243] usbcore: registered new interface driver uas
[    3.069775] usbcore: registered new interface driver usb-storage
[    3.075910] usbcore: registered new interface driver ums-alauda
[    3.081925] usbcore: registered new interface driver ums-cypress
[    3.088021] usbcore: registered new interface driver ums-datafab
[    3.094115] usbcore: registered new interface driver ums_eneub6250
[    3.100510] usbcore: registered new interface driver ums-freecom
[    3.106691] usbcore: registered new interface driver ums-isd200
[    3.112739] usbcore: registered new interface driver ums-jumpshot
[    3.118928] usbcore: registered new interface driver ums-karma
[    3.124849] usbcore: registered new interface driver ums-onetouch
[    3.131062] usbcore: registered new interface driver ums-realtek
[    3.137165] usbcore: registered new interface driver ums-sddr09
[    3.143309] usbcore: registered new interface driver ums-sddr55
[    3.149325] usbcore: registered new interface driver ums-usbat
[    3.158881] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[    3.178690] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[    3.209294] omap_rtc 44e3e000.rtc: registered as rtc0
[    3.215783] i2c /dev entries driver
[    3.224078] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    3.231658] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    3.243750] ledtrig-cpu: registered to indicate activity on CPUs
[    3.250661] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    3.256885] omap-aes 53500000.aes: will run requests pump with realtime priority
[    3.267614] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    3.278716] hidraw: raw HID events driver (C) Jiri Kosina
[    3.284742] usbcore: registered new interface driver usbhid
[    3.290714] usbhid: USB HID core driver
[    3.295205] remoteproc remoteproc0: wkup_m3 is available
[    3.304511] drop_monitor: Initializing network drop monitor service
[    3.312159] NET: Registered protocol family 10
[    3.325892] Segment Routing with IPv6
[    3.330004] mip6: Mobile IPv6
[    3.333002] NET: Registered protocol family 17
[    3.337837] can: controller area network core (rev 20170425 abi 9)
[    3.344288] NET: Registered protocol family 29
[    3.353266] Key type dns_resolver registered
[    3.357702] mpls_gso: MPLS GSO support
[    3.361704] ThumbEE CPU extension supported.
[    3.366056] Registering SWP/SWPB emulation handler
[    3.370903] omap_voltage_late_init: Voltage driver support not added
[    3.377715] PM: Cannot get wkup_m3_ipc handle
[    3.382991] registered taskstats version 1
[    3.387193] Loading compiled-in X.509 certificates
[    3.392214] zswap: loaded using pool lzo/zbud
[    3.397080] Key type ._fscrypt registered
[    3.401168] Key type .fscrypt registered
[    3.409798] Btrfs loaded, crc32c=crc32c-generic
[    3.414559] AppArmor: AppArmor sha1 policy hashing enabled
[    3.483619] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    3.490980] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    3.509607] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    3.515989] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.644460] tda998x 0-0070: found TDA19988
[    3.652725] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc0e88824)
[    3.658791] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.665464] [drm] No driver support for vblank timestamp query.
[    3.672492] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    3.680427] [drm] Cannot find any crtc or sizes
[    3.685359] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    3.692267] [drm] Cannot find any crtc or sizes
[    3.701514] remoteproc remoteproc0: powering up wkup_m3
[    3.708425] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[    3.721265] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    3.726966] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    3.726988] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[    3.740549] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    3.748575] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    3.756999] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.764334] usb usb1: Product: MUSB HDRC host driver
[    3.769473] usb usb1: Manufacturer: Linux 5.4.242-bone66 musb-hcd
[    3.775663] usb usb1: SerialNumber: musb-hdrc.1
[    3.781283] hub 1-0:1.0: USB hub found
[    3.785254] hub 1-0:1.0: 1 port detected
[    3.793922] PM: bootloader does not support rtc-only!
[    3.800528] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:01 UTC (946684801)
[    3.811827] VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1): error -6
[    3.820029] Please append a correct "root=" boot option; here are the available partitions:
[    3.828565] b300        15474688 mmcblk0
[    3.828570]  driver: mmcblk
[    3.835501] 0b3:00100    3735552 mmcblk1
[    3.835505]  driver: mmcblk
[    3.842398]   0b3:00101    3734528 mmcblk1p1 00000000-01
[    3.842402]
[    3.849259] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
[    3.857741] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.242-bone66 #1
[    3.864382] Hardware name: Generic AM33XX (Flattened Device Tree)
[    3.870500] Backtrace:
[    3.872980] [<c0d4b4a4>] (dump_backtrace) from [<c0d4b868>] (show_stack+0x20/0x24)
[    3.880586]  r7:60000193 r6:c13c70e4 r5:00000000 r4:c13c70e4
[    3.886279] [<c0d4b848>] (show_stack) from [<c0d5aa24>] (dump_stack+0x8c/0xa0)
[    3.893536] [<c0d5a998>] (dump_stack) from [<c0d4be1c>] (panic+0x14c/0x350)
[    3.900528]  r7:c127e85c r6:c0fccc34 r5:00000000 r4:c13fa9b8
[    3.906222] [<c0d4bcd0>] (panic) from [<c1201a54>] (mount_block_root+0x1e0/0x294)
[    3.913738]  r3:c88dfe90 r2:c88dfe90 r1:dc13fe9c r0:c0fccc34
[    3.919419]  r7:c127e85c
[    3.921966] [<c1201874>] (mount_block_root) from [<c1201c38>] (mount_root+0x130/0x14c)
[    3.929921]  r10:00000008 r9:c127e858 r8:c12006a0 r7:c1309540 r6:dc13e000 r5:c127e871
[    3.937782]  r4:0b300001
[    3.940328] [<c1201b08>] (mount_root) from [<c1201db4>] (prepare_namespace+0x160/0x1a8)
[    3.948369]  r10:00000008 r9:c127e858 r8:c12006a0 r7:c127e838 r6:c13fa000 r5:c127e871
[    3.956230]  r4:c13fa030
[    3.958777] [<c1201c54>] (prepare_namespace) from [<c120158c>] (kernel_init_freeable+0x24c/0x260)
[    3.967686]  r5:c13fa000 r4:c114945c
[    3.971279] [<c1201340>] (kernel_init_freeable) from [<c0d5ac20>] (kernel_init+0x18/0x128)
[    3.979581]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0d5ac08
[    3.987442]  r4:00000000
[    3.989991] [<c0d5ac08>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    3.997592] Exception stack(0xdc13ffb0 to 0xdc13fff8)
[    4.002667] ffa0:                                     00000000 00000000 00000000 00000000
[    4.010882] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.019097] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    4.025739]  r5:c0d5ac08 r4:00000000
[    4.029350] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1) ]---
The issue is here… mmcblk0: unable to read partition table your microSD is probably corrupt…
Hi Robert, I tried to boot from the new microSD card but it is still not successful. Any suggestions for this problem
