I am trying to interface 24bit lcd with BeagleBone containing TI android 4.2.2. I have made following changes to board-am335xevm.c kernel 3.2 as in the source file of TI
static const struct display_panel custom_pannel = {
WVGA,
24, //According to the 32bpp display_panel i made it to 24 for my 24 bit lcd
24, //which i am using
COLOR_ACTIVE,
I am using the following lcd_ctrl_config
static struct lcd_ctrl_config lcd1_cfg = {
&custom_pannel,
.ac_bias = 255,
.ac_bias_intrpt = 0,
.dma_burst_sz = 16,
.bpp = 24, // 24 bit lcd
.fdd = 0x80,
.tft_alt_mode = 0,
.stn_565_mode = 0,
.mono_8bit_mode = 0,
.invert_line_clock = 1,
.invert_frm_clock = 1,
.sync_edge = 0,
.sync_ctrl = 1,
.raster_order = 0,
following addition to file for my custom display pdata
struct da8xx_lcdc_platform_data buydisplay_pdata = {
.manu_name = “ThreeFive”,
.controller_data = &lcd1_cfg,
.type = “buydisplay”,
/* Module pin mux for LCDC */
static struct pinmux_config lcdc_pin_mux = {
{“lcd_data0.lcd_data0”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data1.lcd_data1”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data2.lcd_data2”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data3.lcd_data3”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data4.lcd_data4”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data5.lcd_data5”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data6.lcd_data6”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data7.lcd_data7”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data8.lcd_data8”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data9.lcd_data9”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data10.lcd_data10”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data11.lcd_data11”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data12.lcd_data12”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data13.lcd_data13”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data14.lcd_data14”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“lcd_data15.lcd_data15”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT
AM33XX_PULL_DISA},
{“gpmc_ad8.lcd_data16”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad9.lcd_data17”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad10.lcd_data18”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad11.lcd_data19”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad12.lcd_data20”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad13.lcd_data21”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad14.lcd_data22”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“gpmc_ad15.lcd_data23”, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT},
{“lcd_vsync.lcd_vsync”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{“lcd_hsync.lcd_hsync”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{“lcd_pclk.lcd_pclk”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{“lcd_ac_bias_en.lcd_ac_bias_en”, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT},
{NULL, 0},
Following is my init file
static void buydisplay_init(int evm_id, int profile)
pr_info(“IN : %s \n”, FUNCTION);
// setup_pin_mux(lcd_cape_pin_mux);
setup_pin_mux(lcdc_pin_mux);
if (conf_disp_pll(50000000)) {
pr_info(“Failed configure display PLL, not attempting to”
“register LCDC\n”);
return;
gpio_request(beaglebone_lcd_avdd_en, “BONE_LCD_AVDD_EN”);
gpio_direction_output(beaglebone_lcd_avdd_en, 1);
if (am33xx_register_lcdc(&buydisplay_pdata))
pr_info(“Failed to register LCDC device\n”);
pr_info(“Setup LCD display\n”);
return;
I have made following changes to da8xxfb.c in TI_Android_JB_4.2.2_DevKit_4.1.1/kernel/drivers/video/da8xx-fb.c
under
static struct da8xx_panel known_lcd_panels = {
10] = {
.name = “buydisplay”,
.width = 800,
.height = 480,
.hfp = 40, // 20
.hbp = 88, // 54
.hsw = 48,
.vfp = 13,
.vbp = 32,
.vsw = 3,
.pxl_clk = 50000000,
.invert_pxl_clk = 0,
My cross compile toolchain path is
export PATH=/home/mihir/TI_Android_JB_4.2.2_DevKit_4.1.1/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin:$PATH
and i have compiled the kernel using following command by changing my directory to " TI_Android_JB_4.2.2_DevKit_4.1.1/kernel/ " and compiled my kernel using
make ARCH=arm CROSS_COMPILE=arm-eabi- distclean
make ARCH=arm CROSS_COMPILE=arm-eabi- am335x_evm_android_defconfig
make ARCH=arm CROSS_COMPILE=arm-eabi- uImage
The image is successfully getting generated
But there is no display on the LCD which is connected. I have considered the errate sheet LCD section for my connections.
By looking into the kernel log the following is noted on terminal
1.266693] IN : bone_setup_display_daughter_board
[ 1.331512] No display cape found on BeagleBone
[ 1.336730] da8xx_lcdc.0: alias fck already exists
[ 1.342071] da8xx_lcdc da8xx_lcdc.0: GLCD: Found Sharp_LCD035Q3DG01 panel
Are there any specific guidelines to adding a custom 24 bit LCD to beaglebone ReV A6 running android?
Am I missing any part in kernel compilation?
Can you point out any other files that i need to edit?
