Still fingers crossed 7.3.x will become a full lts.. (it’s not in stone till it’s listed here: The Linux Kernel Archives - Releases )
You’ll see the new 7.3.x image show up in bb-imager-rs Redirect Notice
first bug
sudo poweroff does not shut down the board (waited over 5 minutes)
the lights remain flashing
edit:
sudo reboot also does not reboot, same log as below
uname -a
Linux bbbtest 7.3.5-bone12 #1 SMP PREEMPT Tue Nov 17 19:38:09 UTC 2026 armv7l GNU/Linux
debian@bbbtest:~$ sudo poweroff
Broadcast message from root@bbbtest on pts/0 (Tue 2026-11-24 11:06:26 CST):
The system will power off now!
debian@bbbtest:~$
Stopping session-1.scope - Session 1 of User debian…
[ OK ] Removed slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Stopped target graphical.target - Graphical Interface.
[ OK ] Stopped target sound.target - Sound Card.
[ OK ] Stopped target timers.target - Timer Units.
[ OK ] Stopped apt-daily-upgrade.timer - …y apt upgrade and clean activities.
[ OK ] Stopped apt-daily.timer - Daily apt download activities.
[ OK ] Stopped dpkg-db-backup.timer - Daily dpkg database backup timer.
[ OK ] Stopped e2scrub_all.timer - Period…Metadata Check for All Filesystems.
[ OK ] Stopped fstrim.timer - Discard unused filesystem blocks once a week.
[ OK ] Stopped logrotate.timer - Daily rotation of log files.
[ OK ] Stopped man-db.timer - Daily man-db regeneration.
[ OK ] Stopped systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
[ OK ] Stopped target time-set.target - System Time Set.
[ OK ] Closed systemd-rfkill.socket - Loa…ll Switch Status /dev/rfkill Watch.
Stopping gpio-manager.service - Centralized GPIO manager daemon…
Stopping polkit.service - Authorization Manager…
Stopping systemd-networkd-persiste…tent Storage in systemd-networkd…
Stopping systemd-random-seed.service - Load/Save OS Random Seed…
[ OK ] Stopped systemd-udev-load-credenti…- Load udev Rules from Credentials.
Stopping wtmpdb-update-boot.servic…t and shutdown times into wtmpdb…
[ OK ] Stopped polkit.service - Authorization Manager.
[ OK ] Stopped serial-getty@ttyS0.service - Serial Getty on ttyS0.
Which of the am335x beagle variant is this. I’m mostly tracking reboot, uptime, and stablity… don’t really have a way to shutdown (reset power) and turn back on. ![]()
sorry, now that there is that other one.
this is on the Rev C
emmc has been erased.
perfect, revc… this should be the first version that fully supports the ‘eco’ which has a different pmic.. one of the big changes is the watchdog is actually working vs older images..
yeap also waiting..
Debian GNU/Linux 13 BBB-test ttyS0
BeagleBoard.org Debian Trixie Base Image 2026-11-23
Support: https://bbb.io/debian
default username is [voodoo]
Web console: https://localhost:9090/
BBB-test login: voodoo
Password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
voodoo@BBB-test:~$ sudo systemctl poweroff
[sudo] password for voodoo:
Broadcast message from root@BBB-test on pts/0 (Tue 2026-11-24 12:03:27 CST):
voodoo@BBB-test:~$
Stopping session-1.scope - Session 1 of User voodoo...
[ OK ] Stopped apt-daily-upgrade.timer - Daily apt upgrade and clean activities.
[ OK ] Stopped apt-listchanges.timer - Try hourly to initialize apt-listchanges database for APT.
[ OK ] Stopped e2scrub_all.timer - Periodic ext4 Online Metadata Check for All Filesystems.
[ OK ] Stopped systemd-tmpfiles-clean.timer - Daily Cleanup of Temporary Directories.
[ OK ] Closed systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping gpio-manager.service - Centralized GPIO manager daemon...
Stopping polkit.service - Authorization Manager...
Stopping systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd...
Stopping systemd-random-seed.service - Load/Save OS Random Seed...
[ OK ] Stopped systemd-udev-load-credentials.service - Load udev Rules from Credentials.
Stopping wtmpdb-update-boot.service - Write boot and shutdown times into wtmpdb...
Trying:
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 omap_wdt.early_enable=1 systemd.log_level=debug systemd.log_target=kmsg printk.devkmsg=on log_buf_len=1M systemd.show_status=1 ignore_loglevel] ...
7.3.x-shutdown.log (184.7 KB)
Now trying:
cmdline=fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 omap_wdt.early_enable=1 systemd.show_status=0
Side note… watchdog… should maybe trigger in 10 minutes.. (just waiting right now)..
nope.. 10 minutes.. .no reset… (still on..)
here is my work around
ssh-keygen -t rsa
cat .ssh/id_rsa.pub | ssh user@ip 'cat >> .ssh/authorized_keys'
both
sudo reboot
and
sudo poweroff
work
So… if you login with ssh, and then still shutdown thru serial it will power off.. if you don’t login thru ssh, the next time it’ll still lock up!
I’m been having fun going back and fork with claude on this.. i forget what i’m even checking now! ![]()
installing rsa keys and providing id_rsa.pub from your machine via serial console everything seems to work,. not sure why
Think i got it… (or claude figured it with all back and forth logs)..
it’s our friend serial-getty@ttyGS0 again… it’s locked still waiting for a usb port to plug in..
# /etc/systemd/system/serial-getty@ttyGS0.service.d/no-reset.conf
[Service]
TTYReset=no
TTYVHangup=no
TTYVTDisallocate=no
Claude:
systemd 257 / kernel 7.3, BeagleBone Black.
serial-getty@ttyGS0(USB gadget ACM, no host reader): the executor child is stuck pre-exec inwait_woken(syscall …) after the ANSI reset times out, while holdinglock_dev_console(). Later, at shutdown, PID 1 blocks inflock(/dev/console, LOCK_EX)while resetting ttyS0 after serial-getty exits. The event loop stops, D-Bus calls time out, and the shutdown never completes. Expected: no tty operation that can block forever while holding the console lock (use non-blocking I/O or a timeout for the drain).
Might be related bug: Systemd performs dangerous blocking operation on serial terminal in the process 1 · Issue #38281 · systemd/systemd · GitHub (and fixed..)
Trying this on a fresh image:
sudo mkdir /etc/systemd/system/serial-getty@ttyGS0.service.d/
sudo nano /etc/systemd/system/serial-getty@ttyGS0.service.d/no-reset.conf
cat /etc/systemd/system/serial-getty@ttyGS0.service.d/no-reset.conf
[Service]
TTYReset=no
TTYVHangup=no
TTYVTDisallocate=no
Broadcast message from root@BBB-test on pts/0 (Tue 2026-11-24 14:42:26 CST):
voodoo@BBB-test:~$
[ OK ] Stopped apt-listchanges.timer - Tr…e apt-listchanges database for APT.
Stopping systemd-networkd-persiste…tent Storage in systemd-networkd...
Stopping wtmpdb-update-boot.servic…t and shutdown times into wtmpdb...
[ OK ] Stopped unattended-upgrades.service - Unattended Upgrades Shutdown.
[ OK ] Stopped session-1.scope - Session 1 of User voodoo.
[ OK ] Stopped gpio-manager.service - Centralized GPIO manager daemon.
[ OK ] Stopped systemd-random-seed.service - Load/Save OS Random Seed.
[ OK ] Stopped wtmpdb-update-boot.service…oot and shutdown times into wtmpdb.
[ OK ] Stopped target multi-user.target - Multi-User System.
[ OK ] Stopped target getty.target - Login Prompts.
Stopping avahi-daemon.service - Avahi mDNS/DNS-SD Stack...
Stopping bb-usb-gadgets.service - BeagleBoard.org USB gadgets...
Stopping cron.service - Regular ba…ground program processing daemon...
Stopping getty@tty1.service - Getty on tty1...
Stopping nginx.service - A high pe…erver and a reverse proxy server...
Stopping serial-getty@ttyGS0.service - Serial Getty on ttyGS0...
Stopping ssh.service - OpenBSD Secure Shell server...
Stopping user@1000.service - User Manager for UID 1000...
[ OK ] Stopped avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped cron.service - Regular background program processing daemon.
[ OK ] Stopped ssh.service - OpenBSD Secure Shell server.
[ OK ] Stopped getty@tty1.service - Getty on tty1.
[ OK ] Stopped serial-getty@ttyGS0.service - Serial Getty on ttyGS0.
[ OK ] Stopped systemd-networkd-persisten…istent Storage in systemd-networkd.
[ OK ] Removed slice system-getty.slice - Slice /system/getty.
[ OK ] Removed slice system-serial\x2dget…slice - Slice /system/serial-getty.
[ OK ] Stopped nginx.service - A high per… server and a reverse proxy server.
[ OK ] Stopped target network-online.target - Network is Online.
[ OK ] Stopped target nss-lookup.target - Host and Network Name Lookups.
[ OK ] Stopped bb-usb-gadgets.service - BeagleBoard.org USB gadgets.
[ OK ] Stopped target usb-gadget.target - Hardware activated USB gadget.
[ OK ] Stopped user@1000.service - User Manager for UID 1000.
Stopping systemd-user-sessions.service - Permit User Sessions...
Stopping user-runtime-dir@1000.ser…Runtime Directory /run/user/1000...
[ OK ] Stopped systemd-user-sessions.service - Permit User Sessions.
[ OK ] Unmounted run-user-1000.mount - /run/user/1000.
[ OK ] Stopped user-runtime-dir@1000.serv…r Runtime Directory /run/user/1000.
[ OK ] Removed slice user-1000.slice - User Slice of UID 1000.
[ OK ] Stopped target network.target - Network.
[ OK ] Stopped target remote-fs.target - Remote File Systems.
Stopping dbus.service - D-Bus System Message Bus...
Stopping iwd.service - Wireless service...
Stopping networking.service - Raise network interfaces...
Stopping systemd-logind.service - User Login Management...
Stopping systemd-networkd.service - Network Configuration...
[ OK ] Stopped systemd-networkd.service - Network Configuration.
[ OK ] Stopped dbus.service - D-Bus System Message Bus.
[ OK ] Stopped systemd-logind.service - User Login Management.
[ OK ] Stopped networking.service - Raise network interfaces.
[ OK ] Stopped iwd.service - Wireless service.
[ OK ] Stopped target basic.target - Basic System.
[ OK ] Stopped target network-pre.target - Preparation for Network.
[ OK ] Stopped target paths.target - Path Units.
[ OK ] Stopped systemd-ask-password-conso…equests to Console Directory Watch.
[ OK ] Stopped systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[ OK ] Stopped target slices.target - Slice Units.
[ OK ] Removed slice user.slice - User and Session Slice.
[ OK ] Stopped target sockets.target - Socket Units.
[ OK ] Closed avahi-daemon.socket - Avahi…DNS/DNS-SD Stack Activation Socket.
Stopping cockpit.socket - Cockpit Web Service Socket...
[ OK ] Closed dbus.socket - D-Bus System Message Bus Socket.
[ OK ] Closed sshd-unix-local.socket - Op…temd-ssh-generator, AF_UNIX Local).
[ OK ] Closed systemd-hostnamed.socket - Hostname Service Socket.
[ OK ] Closed systemd-networkd.socket - Network Service Netlink Socket.
[ OK ] Stopped systemd-network-generator.…ork Units from Kernel Command Line.
[ OK ] Closed cockpit.socket - Cockpit Web Service Socket.
[ OK ] Stopped target sysinit.target - System Initialization.
[ OK ] Stopped target swap.target - Swaps.
Deactivating swap dev-disk-by\x2dd… - /dev/disk/by-diskseq/12-part2...
Deactivating swap dev-disk-by\x2dd…3.swap - /dev/disk/by-diskseq/13...
Stopping systemd-binfmt.service - Set Up Additional Binary Formats...
Stopping systemd-resolved.service - Network Name Resolution...
Stopping systemd-timesyncd.service - Network Time Synchronization...
[ OK ] Stopped systemd-tmpfiles-setup.ser…reate System Files and Directories.
[ OK ] Stopped systemd-resolved.service - Network Name Resolution.
[ OK ] Deactivated swap dev-disk-by\x2dpa…0.mmc-part/by-partuuid/e28a0638-02.
[ OK ] Deactivated swap dev-disk-by\x2dpa… /dev/disk/by-partuuid/e28a0638-02.
[ OK ] Deactivated swap dev-disk-by\x2dpa…9d98e3-ce6b-4995-b4e3-d8ffe6db8f34.
[ OK ] Deactivated swap dev-disk-by\x2duu…9d98e3-ce6b-4995-b4e3-d8ffe6db8f34.
[ OK ] Deactivated swap dev-disk-by\x2did…k/by-id/mmc-SH32G_0x97a9aa82-part2.
[ OK ] Deactivated swap dev-disk-by\x2dpa…y-path/platform-48060000.mmc-part2.
[ OK ] Deactivated swap dev-disk-by\x2dpa…orm-48060000.mmc-part/by-partnum/2.
[ OK ] Deactivated swap dev-disk-by\x2ddi…ap - /dev/disk/by-diskseq/12-part2.
[ OK ] Deactivated swap dev-disk-by\x2ddi…-13.swap - /dev/disk/by-diskseq/13.
[ OK ] Stopped systemd-timesyncd.service - Network Time Synchronization.
[ OK ] Deactivated swap dev-mmcblk0p2.swap - /dev/mmcblk0p2.
[ OK ] Deactivated swap dev-zram0.swap - Compressed Swap on /dev/zram0.
[ OK ] Stopped systemd-binfmt.service - Set Up Additional Binary Formats.
[ OK ] Unset automount proc-sys-fs-binfmt…ormats File System Automount Point.
[ OK ] Stopped target local-fs.target - Local File Systems.
Unmounting boot-firmware.mount - /boot/firmware...
Unmounting run-lock.mount - Legacy Locks Directory /run/lock...
[ OK ] Stopped systemd-sysctl.service - Apply Kernel Variables.
[ OK ] Stopped systemd-modules-load.service - Load Kernel Modules.
Stopping systemd-zram-setup@zram0.…vice - Create swap on /dev/zram0...
[ OK ] Unmounted boot-firmware.mount - /boot/firmware.
[ 119.250903] zram0: detected capacity change from 490496 to 0
[ OK ] Unmounted run-lock.mount - Legacy Locks Directory /run/lock.
[ OK ] Stopped systemd-zram-setup@zram0.service - Create swap on /dev/zram0.
[ OK ] Removed slice system-systemd\x2dzr…- Slice /system/systemd-zram-setup.
[ OK ] Reached target umount.target - Unmount All Filesystems.
[ OK ] Stopped systemd-fsck@dev-mmcblk0p1…ile System Check on /dev/mmcblk0p1.
[ OK ] Removed slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[ OK ] Stopped target local-fs-pre.target…Preparation for Local File Systems.
[ OK ] Stopped systemd-remount-fs.service…mount Root and Kernel File Systems.
[ OK ] Stopped systemd-fsck-root.service - File System Check on Root Device.
[ OK ] Stopped systemd-tmpfiles-setup-dev…Create Static Device Nodes in /dev.
[ OK ] Stopped systemd-tmpfiles-setup-dev…ic Device Nodes in /dev gracefully.
[ OK ] Reached target shutdown.target - System Shutdown.
[ OK ] Reached target final.target - Late Shutdown Services.
[ OK ] Finished systemd-poweroff.service - System Power Off.
[ OK ] Reached target poweroff.target - System Power Off.
[ 119.921411] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 120.627951] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 120.680498] systemd-journald[241]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 120.760181] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 120.845255] systemd-shutdown[1]: Unmounting file systems.
[ 120.861521] (sd-umount)[752]: Unmounting '/run/credentials/systemd-journald.service'.
[ 120.884847] (sd-remount)[753]: Remounting '/' read-only with options 'errors=remount-ro'.
[ 120.920764] EXT4-fs (mmcblk0p3): re-mounted c802b111-3f69-4556-8151-288277e404f3 ro.
[ 120.965945] systemd-shutdown[1]: All filesystems unmounted.
[ 120.966003] systemd-shutdown[1]: Deactivating swaps.
[ 120.966211] systemd-shutdown[1]: All swaps deactivated.
[ 120.966244] systemd-shutdown[1]: Detaching loop devices.
[ 121.009031] systemd-shutdown[1]: All loop devices detached.
[ 121.009085] systemd-shutdown[1]: Stopping MD devices.
[ 121.009863] systemd-shutdown[1]: All MD devices stopped.
[ 121.009897] systemd-shutdown[1]: Detaching DM devices.
[ 121.010521] systemd-shutdown[1]: All DM devices detached.
[ 121.010556] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[ 121.053140] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 121.062473] systemd-shutdown[1]: Powering off.
[ 121.106505] reboot: Power down
Pushing to: bb-usb-gadgets (1.20261124.0) - fix serial-getty@ttyGS0 shutdown lock… · beagleboard/repos-armhf@d8783d9 · GitHub (will test again on a fresh image then sync on arm64/riscv64) and then rebuild all images again! ![]()
Broadcast message from root@BBB-test on pts/0 (Tue 2026-11-24 15:24:10 CST):
voodoo@BBB-test:~$
[ OK ] Removed slice system-modprobe.slice - Slice /system/mo[ OK ] Stopped target graphical.target - Graphical Interface.
[ OK ] Stopped systemd-hostnamed.service - Hostname Service.
[ 89.895527] zram0: detected capacity change from 490496 to 0
[ 90.584794] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 91.299367] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 91.356419] systemd-journald[241]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 91.439714] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 91.525023] systemd-shutdown[1]: Unmounting file systems.
[ 91.541054] (sd-umount)[755]: Unmounting '/run/credentials/systemd-journald.service'.
[ 91.564313] (sd-remount)[756]: Remounting '/' read-only with options 'errors=remount-ro'.
[ 91.601325] EXT4-fs (mmcblk0p3): re-mounted c802b111-3f69-4556-8151-288277e404f3 ro.
[ 91.642133] systemd-shutdown[1]: All filesystems unmounted.
[ 91.642188] systemd-shutdown[1]: Deactivating swaps.
[ 91.642422] systemd-shutdown[1]: All swaps deactivated.
[ 91.642456] systemd-shutdown[1]: Detaching loop devices.
[ 91.682489] systemd-shutdown[1]: All loop devices detached.
[ 91.682540] systemd-shutdown[1]: Stopping MD devices.
[ 91.694820] systemd-shutdown[1]: All MD devices stopped.
[ 91.694866] systemd-shutdown[1]: Detaching DM devices.
[ 91.695561] systemd-shutdown[1]: All DM devices detached.
[ 91.695598] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[ 91.725487] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 91.736538] systemd-shutdown[1]: Powering off.
[ 91.778576] reboot: Power down
okay i think we are good.. now to build arm64/riscv64
(and the gadget usb connection still works..)
voodoo@hestia:~$ tio /dev/ttyACM1
[15:34:50.593] tio 3.9
[15:34:50.593] Press ctrl-t q to quit
[15:34:50.593] Connected to /dev/ttyACM1
Login incorrect
Password:
voodoo@BBB-test:~$
Okay all images are rebuilding…
Okay all new images affected (20261123) are now updated as of (20261124).. that same change probally fixes a bunch of older images..
looks good, poweroff and reboot both works, thanks,
