I purchased a Beaglebone White, along with a 7" LCD cape and 1.3MP camera, several months ago. At the time I was in the middle of a big project and didn’t have time to “play” with them. A few months later I purchased a Beaglebone Black. Same problem, no free time to work with them. Just in the last couple weeks I have found some free time and have started researching both Beaglebone boards. I plugged the 7" LCD cape into the BBW, after updating the firmware, and it worked. After looking at the compatibility matrix I then plugged the cape into my BBB, again, after updating the firmware, and without the camera. I did not work and the BBB would not boot with the cape in place. I then moved the cape back to the BBW where, now, it failed to work either.
I have been unable to get the LCD to work, after that first test, under any circumstances. Any suggestions? I can’t return it since it is several months old, even though it hasn’t been used.
I suggest you contact the people at beagleboardtoys.com for help.
Terry Gray <twgray2007@gmail.com> [13-08-18 03:52]:
didn't have time to "play" with them. A few months later I purchased a
circumstances. Any suggestions? I can't return it since it is several
months old, even though it hasn't been used.
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
Hi Terry,
You have to disable eMMC and HDMI via uEnv.txt (see commented line
there) before running the LCD7 with the Beaglebone Black if the
LCD7 is an A2 version.
If not doing so you may harm the LCD7.
You also have to prepare a sdcard to boot from.
HTH!
Best regards,
mcc
Hi Terry,
Here you will find further informations:
http://www.elinux.org/BeagleBone_Black_Capes
Below the matrix, there are the following notes:
Notes
RS-232 Cape - Uart5 is not supported without disabling the onboard HDMI, defaults to Uart2 in software
LCD7 Cape - RevA2 only supports booting from microSD card, RevA3 or newer is fully supported
LCD3 Cape - RevA2 or newer is fully supported
LCD4 Cape - RevA1 or newer is fully supported
Best regards,
mcc
