Dear BeagleBoard folks,
I tried to play the Big Buck Bunny trailer [1] using the file from the
QuickTime column with 720p/5.1 surround.
Unfortunately running
$ omapfbplay trailer_720p.mov
it is not running smoothly.
I am using the BeagleBoard demo image from [2] updated with `opkg
update; opkg upgrade` as of now.
$ more /proc/cmdline
ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait mem=99M@0x80000000 mem=128M@0x88000000 omapfb.mode=dvi:1280x1024MR-16@60
$ lsmod
Module Size Used by
g_cdc 25332 0
bufferclass_ti 3389 0
omaplfb 8749 0
pvrsrvkm 124731 2 bufferclass_ti,omaplfb
sdmak 3743 0
lpm_omap3530 6597 0
dsplinkk 125541 1 lpm_omap3530
cmemk 20978 0
rfcomm 33488 0
ircomm_tty 30629 0
ircomm 16429 1 ircomm_tty
irda 163469 2 ircomm_tty,ircomm
ipv6 249183 10
hidp 11193 0
l2cap 30104 4 rfcomm,hidp
bluetooth 49221 3 rfcomm,hidp,l2cap
rfkill 15030 1 bluetooth
rtc_twl 4427 0
rtc_core 12599 1 rtc_twl
mailbox_mach 4183 0
mailbox 3609 1 mailbox_mach
What other information do you need to tell me what I am doing wrong.
Paul
[1] http://www.bigbuckbunny.org/index.php/trailer-page/
[2] http://www.angstrom-distribution.org/demo/beagleboard/
You're trying to play the h264 version, which would need DSP assistance (and likely updated DSP codecs) to play smoothly. In the past we used the MPEG4 ASP version: http://mirror.bigbuckbunny.de/peach/bigbuckbunny_movies/big_buck_bunny_720p_surround.avi
regards,
Koen
Kai
April 2, 2010, 1:21pm
3
$ omapfbplay trailer\_720p\.mov
ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait mem=99M@0x80000000 mem=128M@0x88000000 omapfb\.mode=dvi:1280x1024MR\-16@60
$ lsmod
Module Size Used by
g\_cdc 25332 0
bufferclass\_ti 3389 0
omaplfb 8749 0
pvrsrvkm 124731 2 bufferclass\_ti,omaplfb
sdmak 3743 0
lpm\_omap3530 6597 0
dsplinkk 125541 1 lpm\_omap3530
cmemk 20978 0
rfcomm 33488 0
ircomm\_tty 30629 0
ircomm 16429 1 ircomm\_tty
irda 163469 2 ircomm\_tty,ircomm
ipv6 249183 10
hidp 11193 0
rtc\_twl 4427 0
rtc\_core 12599 1 rtc\_twl
mailbox\_mach 4183 0
mailbox 3609 1 mailbox\_mach
Paul
[1]http://www.bigbuckbunny.org/index.php/trailer-page/
[2]http://www.angstrom-distribution.org/demo/beagleboard/
I suppose you use omapfbplay. The omapfbplay can play only mp4 720p
video at 24fps. But *_720p.mov uses h264. The omapfbplay can not reach
24fps at the moment.
Kai
April 2, 2010, 1:44pm
4
You're trying to play the h264 version, which would need DSP assistance (and likely updated DSP codecs) to play smoothly. In the past we used the MPEG4 ASP version:bigbuckbunny.de - This website is for sale! - bigbuckbunny Resources and Information. …
regards,
Koen
IIRC, a TI doc. mentions DSP codec doesn't support 720p for omap3. I
don't know if there is an update since then.
