I am trying play 720p video through command line using mplayer.
I have set "video=omapfb:mode:1280x720@60 " screen resolution in boot
args.
I am taking video output from HDMI port and DVI-D connected to LCD
which is 18.5".
Video got played but not in smooth way, some frame are getting lost.
Mplayer also shown error at end of video play as per below.
MPlayer dev-SVN-r28346-4.3.3 (C) 2000-2009 MPlayer Team
CPU: ARM
Playing Alexander_Trailer_720p.wmv.
ASF file format detected.
[asfheader] Audio stream found, -aid 1
[asfheader] Video stream found, -vid 2
VIDEO: [WMV3] 1280x720 24bpp 1000.000 fps 7551.0 kbps (921.8
kbyte/s)
Clip info:
name:
author:
copyright:
comments:
vo: couldn't open the X11 display ()!
VO XOverlay need a subdriver
[VO_SDL] SDL initialization failed: Unable to open a console terminal.
I tried to play video with mplayer with different user login then
root, it played on LCD.
Video isn't displaying proper means some frames are getting lost and
also getting some square black block in down part of video sometimes.
I have set "video=omapfb:mode:1280x720@60 " as video resolution. Video
is not fit to screen of LCD(18.5" inch), some part of video is going
outside of screen also.
Once mplayer got crashed after playing few second video, like below
console data
/************************mplayer crashed
console**************************/
CPU: ARM
kbyte/s)
Clip info:
name:
author:
copyright:
comments:
