Hi, I am running the recommended image for the BBAI64,
I get a lot of error messages like these:
[ 296.846852] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[ 296.853723] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[ 297.042657] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
. what is this ?
. is it possible to get rid of them ? They are polluting my serial console so much that i can’t type
bye
Nicola
Looks like display panel stuff. Have you got a monitor connected ?
EDID is to do with getting monitor resolutions.
Not seen that on my board, but I am using it headless.
nmingotti:
cdns-mhdp8546
Yes, that driver is a little noisy… do you have something plugged into the miniDisplayport?
yes, i confirm it is related to the screen.
removing the miniDisplay connected cable the error message goes away.
Indeed i have issues with the screen also. I will open another thread for that.
I ran into these errors using the Amazon Basics Mini DisplayPort to HDMI Cable. When using my normal DisplayPort cable, things worked fine.
Unfortunately my spare monitor does not have HDMI. I wonder if a DisplayPort to HDMI adapter would work. Maybe only some work?
make sure it’s labled as ‘active’…
