What is the absolute minimal OS that can be installed on this device if I only need it to run inferences using a docker container? This is so I can install ROS2 on the device to use is for edge inferencing. For some reason, I was unable to install the Debian v6…1.x Minimal and get it to boot - even using a MicroSSD card that could boot the device using the XFCE version.
Do you have a ttl adapter on the linux port. Need to watch the boot and see where it hangs. Without the linux port information you are chasing your tail. Also a link to the exact image you are loading.
