Access to micro SD
Hi All and thanks for this fantastic community.
I’m a new user of BeagleBone Black and I’m excited to have one in my hands.
My problem is the following: I tried to plug in a micro-SD 2GB but I couldn’t see the card (it is not listed with fdisk).
I thought I could solve by updating the operative system, so I tried to flash the Angstrom Distribution (BeagleBone Black - 2GB eMMC) and did the following:
  • unpack the file Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.12-beaglebone-2013.06.20.img.xz
  • use dd command to transfer to the SD on my MAC
  • powered down the BBB and plugged in the SD card
  • pressed the USER/BOOT button
  • powered the BBB
Effect is that the Power Led (the one close to power connector) stays ON forever.
In order to recover I have to remove the micro-SD and restart the BBB.
Does someone knows what could be wrong?
I have also tried Ubuntu image but issue is the same.
Thanks a lot,
Vince
I suggest you use the latest image that has this issue fixed. Go to the link on the white card that came in the box.
http://circuitco.com/support/BeagleBoneBlack
Also did you try to use the 2GB micro-SD to install the new OS? You have t o use a 4GB micro-SD.
Yves
Yes, I have used a 2GB... I go to by a 4GB SD immediately and let you know. Thanks for the fast feedback!
Vince
I bought a 8GB SD Card and it works like a charm… Thanks for the support,
Vince
