In my BBB application, I would like to access the cape eeprom to verify that the correct cape is connected. I thought I could just perform an i2c read at the beginning of my application code and verify the eeprom contents, but my application is giving the ioctl busy response when I try to read the eeprom. Is the kernel occupying these addresses? If so, is there a way I can disable that?
I do see the following when I run dmesg:
[ 1.279856] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.282174] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.282529] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.282855] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.283167] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.283253] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
These are the reserved cape eeprom addresses, and I’m guessing that the kernel is occupying these addresses, can I force the kernel to release them, or not get them at all?
