Just booted my new BeaglePlay and checking things out.
I can see the 2 PRUSS available in /sys/class/remoteproc
however don’t see the M4F MCU?
Digging around, I see in /opt/source there is a k3-am62-mcu.dtsi file available that references the MCU, however not sure how to “apply” it?
Any ideas?
You’ll need to git pull
on that directory, i just pushed the BeaglePlay public changes last night…
@Nishanth_Menon worked on openocd support for the m4: Commits · nmenon/openocd · GitHub
I forget where he posted building and running directions on the M4.
Thanks @RobertCNelson
I did a pull and see lots of changes to k3-am625-beagleplay.dts
can you remind me how to apply this? I know there is a Make command somewhere…
cd /opt/source/<dtb dir>
make
sudo make install_arm64
sudo reboot
https://review.openocd.org/c/openocd/+/7091/4 - I have been deliquent in getting the review comments incorportated and posting an update … will try to do it soon (timeframe subject to “mainjob” loads)
I had been working on GitHub - nmenon/bbai64_cortex-r5_example at cortex-m4f though I have’nt had time to finish it up… But see the usage here: bbai64_cortex-r5_example/Makefile at cortex-m4f · nmenon/bbai64_cortex-r5_example · GitHub → been sometime before i got distracted… but probably is a good starting point.
Completed, but still nothing in remoteproc M4F related. Do I need to adjust something in extlinux.conf?
Here is beagle-version output.
eeprom:[BEAGLEPLAY-A0-02007801030101640623001478SSSS]
model:[BeagleBoard.org_BeaglePlay]
dogtag:[BeagleBoard.org Debian Bullseye Xfce Image 2023-02-04]
bootloader:[/dev/mmcblk0boot0]:[tiboot3.bin]:[U-Boot SPL 2021.01-gb248392d (Jan 04 2023 - 19:38:45 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/tiboot3.bin]:[U-Boot SPL 2021.01-gb248392d (Jan 04 2023 - 19:38:45 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/tispl.bin]:[U-Boot SPL 2021.01-gb248392d (Jan 04 2023 - 19:38:45 +0000)]
bootloader:[/dev/mmcblk0]:[/boot/firmware/u-boot.img]:[U-Boot 2021.01-gb248392d (Jan 04 2023 - 19:38:45 +0000)]
kernel:[5.10.162-ti-arm64-r96]
nodejs:[v12.22.12]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-u-boot-sk-am62]:[2021.01.20230302.1-0~bullseye+20230302]
pkg:[bb-customizations]:[1.20230309.0-0~bullseye+20230309]
pkg:[bb-usb-gadgets]:[1.20230216.0-0~bullseye+20230216]
pkg:[bb-wl18xx-firmware]:[1.20221220.0-0~bullseye+20221220]
cmdline:[root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet]
dmesg | grep remote
[ 3.939127] remoteproc remoteproc0: 30074000.pru is available
[ 3.939766] remoteproc remoteproc1: 30078000.pru is available
dmesg | grep pru
dmesg | grep pinctrl-single
[ 1.611999] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 1.612551] pinctrl-single f4000.pinctrl: 171 pins, size 684
dmesg | grep gpio-of-helper
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lspci
END
You are correct. I just looked at the code and realized that after bringing m4f, somewhere down the line of development I had disabled m4f and that got into the production image. will try and see about getting a fix over to Robert real soon unless someone beats me to it…
No worries. Thanks @Nishanth_Menon !
beagleboard:5.10-arm64
← nmenon:fix-play-m4f
opened 01:22AM - 14 Mar 23 UTC
Fixup the RTI which was creating problems for M4F startup - M4F is tightly coupl… ed to the processor itself, and the intent was for M4F to manage the RTI watchdog and usage by A53 is not practical.
or if things are’nt yet synced up: gist:93f4699644bd7d5c2fd852db1be1923e · GitHub (see Steps to modify and build device tree for BeaglePlay - YouTube for example → to build and install)
I used am62xx « ti-ipc - processor-firmware/ti-linux-firmware - Consolidated central location of various TI firmware source and binary projects hosted previously in various locations. firmware for testing. I copied the firmware to /lib/firmware
Thanks for this, watched the video and looks good so far.
@RobertCNelson hasn’t accepted the patch yet, but I know those guys are busy with Munich so will wait a few days for everything to get synced.
Sorry for the delay, Travel/Weather with Embedded World this year, was a mess…
Merge: Commits · v5.10.x-ti-unified · BeagleBoard.org / BeagleBoard-DeviceTrees · GitLab
Tagging as 5.10.162-ti-arm64-r97
No worries! Hope you enjoyed your beer and sausages in Germany!
Btw, just updated and works fine.
awesome. I have been playing with some baremetal code for m4f in the meanwhile…
Rust baremetal code on beagleplay / AM62x M4F · GitHub i will keep it updated as my story progresses…
