I am trying to access my webcam with OpenCV. I installed OpenCV, and the samples are working fine. But I can’t make the webcam work. It’s a Microsoft LifeCam Cinema. I know that there are some issues with it (http://www.ideasonboard.org/uvc/#footnote-13) but it’s said to be working.
Here is the output of dmesg:
[ 8925.347137] usb 2-2.4.3: new high speed USB device using ehci-omap and address 8
[ 8925.489044] usb 2-2.4.3: New USB device found, idVendor=045e, idProduct=075d
[ 8925.496490] usb 2-2.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8925.504333] usb 2-2.4.3: Product: Microsoft�� LifeCam Cinema™
[ 8925.510528] usb 2-2.4.3: Manufacturer: Microsoft
[ 8926.635742] 8:3:1: cannot get freq at ep 0x82
and here is the output of lsusb:
lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 002 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 002 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 005: ID 04d9:1603 Holtek Semiconductor, Inc.
Bus 002 Device 006: ID 045e:0040 Microsoft Corp. Wheel Mouse Optical
Bus 002 Device 008: ID 045e:075d Microsoft Corp.
I installed v4l-utils, libv4l-dev and kernel-module-uvcvideo with opkg. I don’t see uvcvideo module in the lsmod output. Should I do something else to load the module?
lsmod
Module Size Used by
ipv6 249063 10
In my program, the function cvCaptureFromCAM() is always failing.
CvCapture * capture;
capture = cvCaptureFromCAM(-1);
and the driver is not listed with lsmod. I installed it with the command “opkg install kernel-module-uvcvideo” Should I install something else? Or activate it somehow?
best wishes,
I have discovered that kernel-module-uvcvideo package contains the driver (uvcvideo) but does not automatically load it. I loaded it with the command:
