Hi there,
I have some problems of activating the CAN1 Bus for my BeagleBoneBlack.
With 3.8.13 I activated the BUS according http://www.embedded-things.com/bbb/enable-canbus-on-the-beaglebone-black/ with the cape_manger and it worked quiet well.
Now I have installed 3.19 and work with dtb-rebuilder.
What I have done so far:
In the file am335x-boneblack.dts I have outcommented those two lines:
#include "am335x-can1.dtsi"
#include "am335x-bone-can1.dtsi"
After make, make install (no errors), reboot modprobe, activation of can1 bus etc… I get 1:1 the same result in ifconfig as in 3.8.13(with the cape_manager).
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP MTU:16 Metric:1
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:71
But when I look at the pins in /sys/kernel/debug/pinctrl/44e10800.pinmux/pins I get:
pin 96 (44e10980.0) 00000037 pinctrl-single
pin 97 (44e10984.0) 00000037 pinctrl-single
and for /sys/kernel/debug/pinctrl/44e10800.pinmux/pinmux-pins
pin 96 (44e10980.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 97 (44e10984.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
In 3.8.13 (where it works) I have those values:
In /sys/kernel/debug/pinctrl/44e10800.pinmux/pins
pin 96 (44e10980) 00000012 pinctrl-single
pin 97 (44e10984) 00000032 pinctrl-single
pin 96 (44e10980): 481d0000.d_can (GPIO UNCLAIMED) function dcan1_pins_s0 group dcan1_pins_s0
pin 97 (44e10984): 481d0000.d_can (GPIO UNCLAIMED) function dcan1_pins_s0 group dcan1_pins_s0
So it looks like that the MUX has not been set. Anybody a Idea for a solution in the dtb-rebuilder or another idea?
Thanks in advance!!
Best greetings from Austria.
Benjamin
