Hi;
I would like to ask something about connection to beaglebone from my computer via adb.
Android is running my beaglebone and my aim is to send project files (.apk , .so , .xml, .ini) to beaglebone and run via adb
How can I run an android project consisting of .so files .xml files .apk on my beaglebone and where do I have to place these files in beaglebone file system.
Is there any suggestion for this problem?
This is really an Android related question:
computer via adb.
not beaglebone specific read but
It *should* be very simple on the bone as the hub in the bone is also
connected to the SoC's usb port.
Perhaps look at "developer options -> enable adb"
This is supported by adb just make sure you are connected either via
usb if that works of worst case over tcpip.
system.
Really just create an APK in eclipse and run your code. If you have
native code use the android-ndk
to compile them (You will need to write a little java code or
implement a native activity)
You are better to start of developing using the standard Android tools
(eclipse,adb, and the emulator) . once that works
you can move to the beaglebone.
Greetings
Thank you so much for suggestions i will do that
27 Tem 2012 10:23 tarihinde “Kees Jongenburger” <kees.jongenburger@gmail.com> yazdı:
