I am trying to follow the tutorial for the accelerometer found here: http://beagleboard.org/Support/BoneScript/accelerometer/
If I read it right I should be getting back a 1.0 as the resting state on the table. However I get back this:
Analog Read Value x: -4.853507815339876
Analog Read Value y: -4.8716830243547795
Analog Read Value z: -4.835332606324972
I am using the ADXL335 Accelerometer and 470-0ohm 1/4 watt carbon film resistors from radio shack.
So do I just change the below offset and conversion factor? If so how do I find those?
Source code:
var b = require(‘bonescript’);
var zeroOffset = 0.4584;
var conversionFactor = 0.0917;
function callADC(){
b.analogRead(‘P9_36’, printX);
b.analogRead(‘P9_38’, printY);
b.analogRead(‘P9_40’, printZ);
function printX(x) {
var value = (x.value - zeroOffset)/conversionFactor;
console.log('Analog Read Value x: ’ +value.toFixed(6));
// when the ADXL335 resting flat on a table or
//board, then readings should be x:0
function printY(x) {
console.log('Analog Read Value y: ’ +value.toFixed(6));
//board, then readings should be y:0
function printZ(x) {
console.log(‘Analog Read Value z: ’ +value.toFixed(6));
//board, then readings should be z:1
console.log(’’);
//callADC will be invoked 20 times a sec or once every 50 ms
var loop = setInterval(callADC, 250);
function clear(){
clearInterval(loop);
