I followed all the commands written such as setting bootargs and loading uimage and dtb file
but on loading the kernel, it is stuck and the last logs I see are those:
[ OK ] Found device /dev/ttyO0.
[ OK ] Reached target Sound Card.
[ TIME ] Timed out waiting for device dev-ttyGS0.device.
[DEPEND] Dependency failed for Serial Getty on ttyGS0.
this is the entire log
U-Boot# load mmc 1:2 0x82000000 /boot/uImage
4270840 bytes read in 730 ms (5.6 MiB/s)
U-Boot# load mmc 1:2 0x88000000 /boot/am335x-boneblack.dtb
24129 bytes read in 32 ms (736.3 KiB/s)
U-Boot# setenv bootargs console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw
U-Boot# bootm 0x82000000 - 0x88000000
Booting kernel from Legacy Image at 82000000 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Using Device Tree in place at 88000000, end 88008e40
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (koen@rrMBP) (gcc version 4.7.3 20130205 (pr erelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Tue Jun 18 02:11:09 EDT 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0af3000 s9408 r8192 d15168 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 r w
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memor y cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 510560k/510560k available, 13728k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05d5914 (5943 kB)
[ 0.000000] .init : 0xc05d6000 - 0xc06174c0 ( 262 kB)
[ 0.000000] .data : 0xc0618000 - 0xc0689ca0 ( 456 kB)
[ 0.000000] .bss : 0xc0689ca0 - 0xc06e36bc ( 359 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895 6ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000352] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015426] pid_max: default: 32768 minimum: 301
[ 0.015659] Security Framework initialized
[ 0.015753] Mount-cache hash table entries: 512
[ 0.025818] Initializing cgroup subsys cpuacct
[ 0.025854] Initializing cgroup subsys memory
[ 0.025916] Initializing cgroup subsys blkio
[ 0.026054] CPU: Testing write buffer coherency: ok
[ 0.026590] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026668] Setting up static identity map for 0x80370ee0 - 0x80370f2c
[ 0.028070] Brought up 1 CPUs
[ 0.028096] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029376] devtmpfs: initialized
[ 0.093900] pinctrl core: initialized pinctrl subsystem
[ 0.094115] rstctl core: initialized rstctl subsystem
[ 0.094604] regulator-dummy: no parameters
[ 0.095110] NET: Registered protocol family 16
[ 0.095899] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.105698] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.106466] platform 49000000.edma: alias fck already exists
[ 0.106499] platform 49000000.edma: alias fck already exists
[ 0.106527] platform 49000000.edma: alias fck already exists
[ 0.107904] OMAP GPIO hardware version 0.1
[ 0.112586] gpio-rctrl rstctl.3: loaded OK
[ 0.117924] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.120066] cpsw.0: No hwaddr in dt. Using 04:a3:16:b5:37:f5 from efuse
[ 0.120100] cpsw.1: No hwaddr in dt. Using 04:a3:16:b5:37:f7 from efuse
[ 0.134462] bio: create slab at 0
[ 0.146469] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.146926] vmmcsd_fixed: 3300 mV
[ 0.149748] SCSI subsystem initialized
[ 0.150225] usbcore: registered new interface driver usbfs
[ 0.150341] usbcore: registered new interface driver hub
[ 0.150615] usbcore: registered new device driver usb
[ 0.152674] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.154166] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-00 24/input/input0
[ 0.156413] DCDC1: at 1500 mV
[ 0.157560] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.158747] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.159843] LDO1: at 1800 mV
[ 0.161013] LDO2: at 3300 mV
[ 0.162938] LDO3: 1800 mV
[ 0.164080] LDO4: at 3300 mV
[ 0.165075] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.165766] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.166530] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.168879] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.169096] media: Linux media interface: v0.10
[ 0.169197] Linux video capture interface: v2.00
[ 0.170012] Advanced Linux Sound Architecture Driver Initialized.
[ 0.171160] Switching to clocksource gp_timer
[ 0.189238] NET: Registered protocol family 2
[ 0.190238] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.190379] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.190542] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.190635] TCP: reno registered
[ 0.190661] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.190708] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191194] NET: Registered protocol family 1
[ 0.191769] RPC: Registered named UNIX socket transport module.
[ 0.191789] RPC: Registered udp transport module.
[ 0.191804] RPC: Registered tcp transport module.
[ 0.191817] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.192870] CPU PMU: probing PMU on CPU 0
[ 0.192900] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counter s available
[ 0.193351] omap2_mbox_probe: platform not supported
[ 0.197219] VFS: Disk quotas dquot_6.5.2
[ 0.197455] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.198690] NFS: Registering the id_resolver key type
[ 0.198795] Key type id_resolver registered
[ 0.198814] Key type id_legacy registered
[ 0.198878] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.199330] msgmni has been set to 997
[ 0.202156] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 50)
[ 0.202183] io scheduler noop registered
[ 0.202199] io scheduler deadline registered
[ 0.202240] io scheduler cfq registered (default)
[ 0.203956] tps65217-bl tps65217-bl: no platform data provided
[ 0.203998] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.204966] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.207489] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.207779] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UA RT0
[ 0.896958] console [ttyO0] enabled
[ 0.901644] [drm] Initialized drm 1.1.0 20060810
[ 0.920193] brd: module loaded
[ 0.930450] loop: module loaded
[ 0.933904] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.941196] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.948490] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.955770] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.963047] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.977299] bone-capemgr bone_capemgr.8: Baseboard: ‘A335BNLT,00C0,3016BBBK1A 41’
[ 0.985090] bone-capemgr bone_capemgr.8: compatible-baseboard=ti,beaglebone-b lack
[ 1.022853] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 1.059953] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 1.097060] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 1.134169] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 1.140427] bone-capemgr bone_capemgr.8: slot #4: specific override
[ 1.147034] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 4
[ 1.155076] bone-capemgr bone_capemgr.8: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.165224] bone-capemgr bone_capemgr.8: slot #5: specific override
[ 1.171827] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 5
[ 1.179868] bone-capemgr bone_capemgr.8: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.189927] bone-capemgr bone_capemgr.8: slot #6: specific override
[ 1.196530] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 6
[ 1.204571] bone-capemgr bone_capemgr.8: slot #6: ‘Bone-Black-HDMIN,00A0,Texa s Instrument,BB-BONELT-HDMIN’
[ 1.215169] bone-capemgr bone_capemgr.8: loader: before slot-4 BB-BONE-EMMC-2 G:00A0 (prio 1)
[ 1.224045] bone-capemgr bone_capemgr.8: loader: check slot-4 BB-BONE-EMMC-2G :00A0 (prio 1)
[ 1.232931] bone-capemgr bone_capemgr.8: loader: before slot-5 BB-BONELT-HDMI :00A0 (prio 1)
[ 1.241703] bone-capemgr bone_capemgr.8: loader: check slot-5 BB-BONELT-HDMI: 00A0 (prio 1)
[ 1.250410] bone-capemgr bone_capemgr.8: initialized OK.
[ 1.256016] bone-capemgr bone_capemgr.8: loader: before slot-6 BB-BONELT-HDMI N:00A0 (prio 2)
[ 1.264871] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 1.275604] OneNAND driver initializing
[ 1.281197] usbcore: registered new interface driver asix
[ 1.286917] bone-capemgr bone_capemgr.8: loader: after slot-4 BB-BONE-EMMC-2G :00A0 (prio 1)
[ 1.295792] usbcore: registered new interface driver cdc_ether
[ 1.301951] bone-capemgr bone_capemgr.8: loader: after slot-5 BB-BONELT-HDMI: 00A0 (prio 1)
[ 1.310640] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 1.319513] usbcore: registered new interface driver smsc95xx
[ 1.325585] bone-capemgr bone_capemgr.8: slot #4: Requesting firmware ‘cape-b one-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.339303] usbcore: registered new interface driver net1080
[ 1.345347] usbcore: registered new interface driver cdc_subset
[ 1.351589] bone-capemgr bone_capemgr.8: slot #4: dtbo ‘cape-bone-2g-emmc1.dt bo’ loaded; converting to live tree
[ 1.362312] bone-capemgr bone_capemgr.8: slot #5: Requesting firmware ‘cape-b oneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[ 1.376505] usbcore: registered new interface driver zaurus
[ 1.382521] usbcore: registered new interface driver cdc_ncm
[ 1.388754] bone-capemgr bone_capemgr.8: slot #4: #2 overlays
[ 1.394833] bone-capemgr bone_capemgr.8: slot #5: dtbo ‘cape-boneblack-hdmi-0 0A0.dtbo’ loaded; converting to live tree
[ 1.406889] usbcore: registered new interface driver cdc_acm
[ 1.412859] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 1.421250] Initializing USB Mass Storage driver…
[ 1.427321] bone-capemgr bone_capemgr.8: slot #4: Applied #2 overlays.
[ 1.434198] bone-capemgr bone_capemgr.8: loader: done slot-4 BB-BONE-EMMC-2G: 00A0 (prio 1)
[ 1.442904] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 1.452771] bone-capemgr bone_capemgr.8: slot #5: #4 overlays
[ 1.460985] platform 4830e000.fb: alias fck already exists
[ 1.467050] usbcore: registered new interface driver usb-storage
[ 1.473396] USB Mass Storage support registered.
[ 1.480022] bone-capemgr bone_capemgr.8: slot #5: Applied #4 overlays.
[ 1.486900] bone-capemgr bone_capemgr.8: loader: done slot-5 BB-BONELT-HDMI:0 0A0 (prio 1)
[ 1.495512] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 1.504480] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.510854] bone-capemgr bone_capemgr.8: loader: after slot-6 BB-BONELT-HDMIN :00A0 (prio 2)
[ 1.520031] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.525298] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps _musb_init: OK
[ 1.534317] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.539390] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.544739] bone-capemgr bone_capemgr.8: slot #6: Requesting firmware ‘cape-b oneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[ 1.559891] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.565175] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps _musb_init: OK
[ 1.574169] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.579233] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.584550] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.590884] bone-capemgr bone_capemgr.8: slot #6: dtbo ‘cape-boneblack-hdmin- 00A0.dtbo’ loaded; converting to live tree
[ 1.602389] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.611014] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8 .45 (#5:BB-BONELT-HDMI)
[ 1.620614] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 1.627392] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BON ELT-HDMIN:00A0 (prio 2)
[ 1.637196] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.644335] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.651919] usb usb1: Product: MUSB HDRC host driver
[ 1.657142] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 1.662818] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.669445] hub 1-0:1.0: USB hub found
[ 1.673460] hub 1-0:1.0: 1 port detected
[ 1.678964] mousedev: PS/2 mouse device common for all mice
[ 1.687241] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.695042] i2c /dev entries driver
[ 1.700390] Driver for 1-wire Dallas network protocol.
[ 1.707307] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.714878] cpuidle: using governor ladder
[ 1.719204] cpuidle: using governor menu
[ 1.723791] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 1.731032] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 1.737464] omap_hsmmc mmc.4: unable to select pin group
[ 1.743308] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.750520] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.757873] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 1.764498] omap_hsmmc mmc.4: pins are not configured from the driver
[ 1.798568] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[ 1.804772] omap_hsmmc mmc.10: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC _RSTn
[ 1.812771] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[ 1.819217] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.826366] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.833884] mmc.10 supply vmmc_aux not found, using dummy regulator
[ 1.840630] omap_hsmmc mmc.10: pins are not configured from the driver
[ 1.874889] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 1.886620] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 1.893931] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.902918] leds-gpio gpio-leds.7: pins are not configured from the driver
[ 1.911275] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.918094] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 1.925352] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.933843] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.940162] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 1.947424] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 1.955716] usbcore: registered new interface driver usbhid
[ 1.961651] usbhid: USB HID core driver
[ 1.969833] davinci_evm sound.13: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 1.981343] TCP: cubic registered
[ 1.984880] Initializing XFRM netlink socket
[ 1.989403] NET: Registered protocol family 17
[ 1.994180] NET: Registered protocol family 15
[ 1.999026] Key type dns_resolver registered
[ 2.003731] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.011926] ThumbEE CPU extension supported.
[ 2.016497] Registering SWP/SWPB emulation handler
[ 2.022599] registered taskstats version 1
[ 2.028274] slave hdmi.12: modes-blacklisted #0 → 1920x1080@25
[ 2.034558] slave hdmi.12: modes-blacklisted #1 → 832x624@75
[ 2.040684] mmc1: BKOPS_EN bit is not set
[ 2.046726] tilcdc 4830e000.fb: No power control GPIO
[ 2.058743] mmc1: new high speed MMC card at address 0001
[ 2.065240] mmcblk0: mmc1:0001 S10004 3.56 GiB
[ 2.070425] mmcblk0boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[ 2.077002] mmcblk0boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[ 2.084770] mmcblk0: p1 p2
[ 2.091588] mmcblk0boot1: unknown partition table
[ 2.099846] mmcblk0boot0: unknown partition table
[ 2.160551] tilcdc 4830e000.fb: found TDA19988
[ 2.166071] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.173024] [drm] No driver support for vblank timestamp query.
[ 2.179619] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 2.186943] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.210572] Console: switching to colour frame buffer device 128x48
[ 2.231826] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.237502] tilcdc 4830e000.fb: registered panic notifier
[ 2.243198] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.300207] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.306626] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.314140] libphy: 4a101000.mdio: probed
[ 2.318393] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.328260] Detected MACID = 04:a3:16:b5:37:f5
[ 2.332910] cpsw 4a100000.ethernet: NAPI disabled
[ 2.339591] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.355918] ALSA device list:
[ 2.359069] #0: TI BeagleBone Black
[ 2.365797] EXT3-fs (mmcblk0p2): error: couldn’t mount because of unsupported optional features (240)
[ 2.376289] EXT2-fs (mmcblk0p2): error: couldn’t mount because of unsupported optional features (244)
[ 3.692442] EXT4-fs (mmcblk0p2): recovery complete
[ 3.700676] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.709209] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.716379] devtmpfs: mounted
[ 3.719792] Freeing init memory: 260K
[ 3.868624] systemd[1]: systemd 196 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX +IMA +SYSVINIT -LIBCRYPTSETUP +GCRYPT +ACL +XZ; angstrom)
Welcome to The Ångström Distribution!
[ 3.920129] systemd[1]: Inserted module ‘autofs4’
[ 3.926665] systemd[1]: Set hostname to .
[ 4.125959] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.134604] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.142691] systemd[1]: Expecting device dev-ttyO0.device…
[ 4.155794] systemd[1]: Expecting device dev-ttyGS0.device…
[ 4.169450] systemd[1]: Starting Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.183081] systemd[1]: Reached target Remote File Systems.
[ 4.189063] systemd[1]: Starting Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.200660] systemd[1]: Listening on Syslog Socket.
[ 4.205886] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.222144] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.229575] systemd[1]: Starting Delayed Shutdown Socket.
[ OK ] Listening on Delayed Shutdown Socket.
[ 4.243636] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.249809] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 4.258509] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.267154] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ OK ] Set up automount Arbitrary Executable File Formats F…utomount Point.
[ 4.286632] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.297014] systemd[1]: Starting udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.310055] systemd[1]: Listening on udev Kernel Socket.
[ 4.316122] systemd[1]: Starting udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.329588] systemd[1]: Listening on udev Control Socket.
[ 4.335393] systemd[1]: Starting Swap.
[ OK ] Reached target Swap.
[ 4.345195] systemd[1]: Reached target Swap.
[ 4.349803] systemd[1]: Starting Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.362785] systemd[1]: Listening on Journal Socket.
[ 4.368118] systemd[1]: Starting Syslog.
[ OK ] Reached target Syslog.
[ 4.378392] systemd[1]: Reached target Syslog.
[ 4.383205] systemd[1]: Started File System Check on Root Device.
[ 4.389736] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.409154] systemd[1]: Starting udev Kernel Device Manager…
[ 4.430548] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.453726] systemd[1]: Mounted Huge Pages File System.
[ 4.467500] systemd[1]: Starting udev Coldplug all Devices…
[ 4.501212] systemd[1]: Starting Apply Kernel Variables…
[ 4.530200] systemd[1]: Starting Journal Service…
Starting Journal[ 4.548975] systemd-udevd[85]: starting version 196
Service…
[ OK ] Started Journal Service.
[ 4.571957] systemd[1]: Started Journal Service.
[ 4.586411] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.606048] systemd[1]: Mounting Debug File System…
[ 4.631217] systemd[1]: Started Machine ID first boot configure.
[ 4.654340] systemd[1]: Starting Load Kernel Modules…
[ OK ] Started udev Kernel Device Manager.
[ 4.700908] systemd[1]: Started udev Kernel Device Manager.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.722312] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Started Apply Kernel Variables.
[ 4.745748] systemd[1]: Started Apply Kernel Variables.
[ OK ] Mounted Debug File System.
[ 4.765350] systemd[1]: Mounted Debug File System.
[ 4.933043] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp…
Starting Load Random Seed…
[ OK ] Started Load Random Seed.
[ OK ] Mounted /tmp.
[ OK ] Reached target Local File Sys[ 5.070665] Bluetooth: Core ver 2.16
tems.
Starting Trigger Flushing of Journal to Persistent Storage…
Starting Recreate Volatile Files and Directories…
Starting Run pending postinsts…
[ 5.117698] NET: Registered protocol family 31
[ 5.122561] Bluetooth: HCI device and connection manager initialized
[ 5.175306] Bluetooth: HCI socket layer initialized
[ OK ] Started Trigger Flushing of Journal to Persis[ 5.225478] Bluetooth: L2CAP socket layer initialized
tent Storage.
[ 5.233923] Bluetooth: SCO socket layer initialized
[ OK ] Started Recreate Volatile Files and Directories.
[ 5.293816] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ OK ] Started udev Coldplug all Devices.
[ 5.335233] Bluetooth: HIDP socket layer initialized
[ 5.361079] systemd-modules-load[98]: Inserted module ‘hidp’
[ 5.447166] NET: Registered protocol family 10
[ 5.470625] systemd-modules-load[98]: Inserted module ‘ipv6’
[ 5.521841] NET: Registered protocol family 23
[ 5.551343] IrCOMM protocol (Dag Brattli)
[ 5.595481] systemd-modules-load[98]: Inserted module ‘ircomm_tty’
[ 5.642144] Bluetooth: RFCOMM TTY layer initialized
[ 5.663565] Bluetooth: RFCOMM socket layer initialized
[ 5.668981] Bluetooth: RFCOMM ver 1.11
[ 5.691081] systemd-modules-load[98]: Inserted module ‘rfcomm’
[ OK ] Started Load Kernel Modules.
[ 5.899502] systemd-journald[94]: Received SIGUSR1
[ 5.957408] systemd-journald[94]: File /var/log/journal/5c860bc642714e9d843b32c8ce70be92/system.journal corrupted or uncleanly shut down, renaming and replacing.
Need help.
