Ok, so after much messing around I have a way to get this going, I have no idea if this is the best way to go about things but it works, it should also help anyone looking at getting pin muxing going.
For this example I am using channel A of ehrpwm0, we can see it in /opt/source/dtb-5.10-ti-arm64/src/arm64/k3-j721e-beagleboneai64.dts:
ehrpwm0_pins_default: ehrpwm0_pins_default {
pinctrl-single,pins = <
J721E_IOPAD(0x164, PIN_OUTPUT, 6) /* (V29) RGMII5_TD2.EHRPWM0_A */
J721E_IOPAD(0x168, PIN_OUTPUT, 6) /* (V27) RGMII5_TD1.EHRPWM0_B */
The next task is trying to work out where that IOPAD is going, if we look in /opt/source/dtb-5.10-ti-arm64/include/dt-bindings/board/k3-j721e-bone-pins.h we can see the mapping of that IOPAD (0x164) to P8_19:
#define P8_19(mode, mux) J721E_IOPAD(0x164, mode, mux) /* V29 */
Now back to the dts we can see the various defines for this pin, these are expanded by the macros BONE_PIN() and P8_19().
BONE_PIN(P8_19, default, P8_19(PIN_INPUT, 7))
BONE_PIN(P8_19, pwm, P8_19(PIN_OUTPUT, 6))
BONE_PIN(P8_19, gpio, P8_19(PIN_INPUT, 7))
BONE_PIN(P8_19, gpio_pu, P8_19(PIN_INPUT_PULLUP, 7))
BONE_PIN(P8_19, gpio_pd, P8_19(PIN_INPUT_PULLDOWN, 7))
So to enable the PWM we have to change cape_header: pinmux_dummy, pinmux_dummy is one of those words that google knows nothing about but It looks like this is what we want in order to change the muxing of the pins.
By default it setup to use the default pinmapping, so to use the PWM we change it to this:
/* Dummy driver to request setup for cape header pins */
cape_header: pinmux_dummy {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <
&P8_03_default_pin
&P8_04_default_pin
&P8_05_default_pin
&P8_06_default_pin
&P8_07_default_pin
&P8_08_default_pin
&P8_09_default_pin
&P8_10_default_pin
&P8_11_default_pin
&P8_12_default_pin
&P8_13_default_pin
&P8_14_default_pin
&P8_15_default_pin
&P8_16_default_pin
&P8_17_default_pin
&P8_18_default_pin
&P8_19_pwm_pin
now build the dts and install it:
cd /opt/source/dtb-5.10-ti-arm64/
make
make install
Now reboot.
when it is up and running we need to setup ehrpwm0 channel A which is pwmchip0 (you can work this out from the address)
cd /sys/class/pwm/pwmchip0
echo 0 > export
cd pwm0
echo 1000 > period
echo 500 > duty_cycle
echo 1 > enable
