AI-64 - remoteproc confusion
I am working on establishing an IPC communication between the Cortex-A72 and the C71x DSP on the BeagleBone AI-64, using remoteproc and rpmsg to send 2 vectors from linux do their multiplication on C71x and read the result back on linux.
I started with simple example: DSP C71x send a “hello world” message to the Cortex-A72 when it receives a “start” message from Cortex-A72. In the main.c file of this example I use RPMessage_recv(), RPMessage_send(),… defined in ipc.h of “ti-processor-sdk-rtos-j721e-evm-11_00_00_06” i get seccusfully the executable and but when i run it on c7x i get this error :
debian@BeagleBone:~$ sudo cp dsp_rpmsg_hello.elf /lib/firmware/
debian@BeagleBone:~$ sudo echo stop > /sys/class/remoteproc/remoteproc14/state
debian@BeagleBone:~$ sudo echo dsp_rpmsg_hello.elf > /sys/class/remoteproc/remoteproc14/firmware
debian@BeagleBone:~$ sudo echo start > /sys/class/remoteproc/remoteproc14/state
echo: write error: Invalid argument
Is there any example that can help me fix this error and how can i establish two sides IPC communication between the Cortex-A72 and the C71x DSP ???
