I am a newbie regarding the Beagleboard XM so please excuse if this is a naive question. On occasions I see the following message on the console using the default image supplied with the board:
Searching the archives I found a suggestion to remove IPv6 support which I did by renaming /lib/modules/2.6.32/kernel/net/ipv6/ipv6.ko to /lib/modules/2.6.32/kernel/net/ipv6/ipv6.ko.orig.
The system appears to still work fine, but I still occasionally get the above message on the console.
There are a few other places in networking code that seem to (at least
sometimes) rely on unaligned trap handling. I've seen it in some ICMP
handlers, for instance.
In my opinion, such code should be fixed so as never to do unaligned
accesses. Unfortunately, the powers that be seem to disagree about
this, and there's nothing I can do.
which tells the kernel to capture and correct illegal memory accesses.
You can also use 3 instead of 2 to prevent the messages from getting
in the log messages.
