I am about to compile and use my version of Angstrom, just wanted to
ask a question (I know it is an old stock kernel)
I am running stock Angstrom 2010.7-test-20110220 (Linux beagleboard
2.6.32 #3 PREEMPT Thu Mar 17 08:56:19 CET 2011 armv7l unknown )
BB-xM rev C is connected to the host PC using a D-link router.
Whenever I ping the board from another machine this warning is emitted
by kernel, for each ping command exactly one line, and completely
reproducible.
[ 72.295623] Alignment trap in kernel: swapper (0) PC=0xc0436954
Instr=0xe8930003 Address=0xdf3c802a FSR 0x001
[ 73.297302] Alignment trap in kernel: swapper (0) PC=0xc0436954
Instr=0xe8930003 Address=0xde49002a FSR 0x001
[ 74.299072] Alignment trap in kernel: swapper (0) PC=0xc0436954
Instr=0xe8930003 Address=0xde44802a FSR 0x001
[ 75.300781] Alignment trap in kernel: swapper (0) PC=0xc0436954
Instr=0xe8930003 Address=0xde41802a FSR 0x001
[ 76.302246] Alignment trap in kernel: swapper (0) PC=0xc0436954
Instr=0xe8930003 Address=0xdf13002a FSR 0x001
[ 77.303985] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 78.305694] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 79.307434] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 80.309143] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 81.310882] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 82.312591] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 83.314361] Alignment trap in kernel: swapper (0) PC=0xc0436954
[ 84.315856] Alignment trap in kernel: gnome-settings- (924)
PC=0xc0436954 Instr=0xe8930003 Address=0xde41802a FSR 0x001
[ 85.317535] Alignment trap in kernel: gvfs-hal-volume (934)
PC=0xc0436954 Instr=0xe8930003 Address=0xdf13002a FSR 0x001
[ 86.319335] Alignment trap in kernel: bonobo-activati (947)
PC=0xc0436954 Instr=0xe8930003 Address=0xdf3c802a FSR 0x001
I disabled ipv6 following another thread using this:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.usb0.disable_ipv6 = 1
and /proc/net/if_inet6 is empty so it confirms ipv6 gone plus ifconfig
shows no ipv6.
But it did not change anything, I know it might be a harmless kernel
warning and my distribution is old.
However I was just curious if it is only me, and if new kernels show
similar symptoms.
thanks
