I'm trying to play some audio on my C3 BeagleBoard. Sadly, I
get nothing but noise when it runs. This same code (just 'aplay')
works fine on my other OMAP/3530 boards.
Any ideas what I might be doing wrong?
Never mind (too early, not enough coffee...)
I used the wrong command (aplay) to play an MP3 file
It's
working fine when I give it good data.
Sorry for the noise.
Have you tried following the instructions on the board validation procedure? Can you follow it and describe the behavior.
it will work fine with angstorm when i loaded audio files in teh sd
card and open with mplayer
