AM335X PRU_RPROC cannot boot any firmware PRU state offline
Hi, I’m trying to bring up the PRU on my BeagleBone Black. I was able to get it up using UIO method, but failed with PRU_RPROC driver.
The pru-software-support-package example compiled OK. I tried PRU_Direct_Connect0 and PRU_RPMsg_Echo_Interrupt1. I copied generated .out file to /lib/firmware. BTW, there was conflicting instructions online about how to place the .out file. One mentioned copying to FILE /lib/firmware/am335x-pru0(1)-fw, and another mentioned copy to under DIRECTORY /lib/firmware/am335x-pru0(1)-fw/. I tried both, and both failed with the same symptom.
I have the following output in dmesg, and it looks as if PRU_RPROC have not even tried to load the .out file.
[   77.864792] pruss 4a300000.pruss: creating PRU cores and other child platform devices
[   77.934664] remoteproc remoteproc1: 4a334000.pru is available
[   77.934794] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully
[   77.936497] remoteproc remoteproc2: 4a338000.pru is available
[   77.936603] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully
The state file under /sys/class/remoteproc/remoteproc2 is showing "offline"
my uEnv.txt file is below:
Pleae have a look at
https://groups.google.com/d/topic/beagleboard/b8W1W3z_xYA/discussion
regards
Thank you, Filippo! It was the exact same issue you mentioned in your post. I tried your solution and it worked like charm.
However, I have one more question. I actually tried to start the PRU using “sudo echo ‘start’ > /sys/class/remoteproc/remoteproc1/state” and it always failed with error “Permission denied”, while in your case, you used sudo sh -c "echo … Is there any significant difference between the two syntax?
On Mon, 24 Sep 2018 08:17:17 -0700 (PDT), Wei Shi
<weishisky@gmail.com> declaimed the
following:
However, I have one more question. I actually tried to start the PRU using "sudo
echo 'start' > /sys/class/remoteproc/remoteproc1/state" and it always
failed with error "Permission denied", while in your case, you used sudo sh
-c "echo ... Is there any significant difference between the two syntax?
  I believe the main difference is that the redirection is handled by
your user shell and only the command before it is passed to sudo.
This probably explained why my “sudo echo” got Permission denied.
