am57-pruss.dtsi and am33-pruss.dtsi?
I am on kernel 6.15.x right now and finding that am57-pruss.dtsi exists.
I cannot find a similar am33-pruss.dtsi file in the works now or in any file so far.
Is there a file for handling PRUSS on the am335x?
P.S. If there is something similar where I can place entries and preprocessor directives, please do contact me. I am trying to handle a beagleg source code on github and coming up short, e.g. even after I can compile things correctly?
I can stop this effort on this post. Thank you for reading it.
P.S. For instance, I can see that these entries have been listed and can be found online:
// SPDX-License-Identifier: GPL-2.0-only
 * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/
 * Common PRUSS data for TI AM57xx platforms
&ocp {
	pruss1_tm: target-module@4b226000 {
		compatible = "ti,sysc-pruss", "ti,sysc";
		reg = <0x4b226000 0x4>,
		      <0x4b226004 0x4>;
		reg-names = "rev", "sysc";
		ti,sysc-mask = <(SYSC_PRUSS_STANDBY_INIT |
				 SYSC_PRUSS_SUB_MWAIT)>;
		ti,sysc-midle = <SYSC_IDLE_FORCE>,
				<SYSC_IDLE_NO>,
				<SYSC_IDLE_SMART>;
		ti,sysc-sidle = <SYSC_IDLE_FORCE>,
				<SYSC_IDLE_NO>,
				<SYSC_IDLE_SMART>;
		/* Domains (P, C): coreaon_pwrdm, l4per2_clkdm */
		clocks = <&l4per2_clkctrl DRA7_L4PER2_PRUSS1_CLKCTRL 0>;
		clock-names = "fck";
		#address-cells = <1>;
		#size-cells = <1>;
		ranges = <0x00000000 0x4b200000 0x80000>;
		pruss1: pruss@0 {
			compatible = "ti,am5728-pruss";
			reg = <0x0 0x80000>;
			#size-cells = <1>;
			ranges;
			pruss1_mem: memories@0 {
				reg = <0x0 0x2000>,
				      <0x2000 0x2000>,
				      <0x10000 0x8000>;
				reg-names = "dram0", "dram1",
					    "shrdram2";
			pruss1_cfg: cfg@26000 {
				compatible = "ti,pruss-cfg", "syscon";
				reg = <0x26000 0x2000>;
				#size-cells = <1>;
				ranges = <0x0 0x26000 0x2000>;
				clocks {
					#size-cells = <0>;
					pruss1_iepclk_mux: iepclk-mux@30 {
						reg = <0x30>;
						#clock-cells = <0>;
						clocks = <&dpll_gmac_m3x2_ck>,  /* icss_iep_clk */
							 <&dpll_gmac_h13x2_ck>; /* icss_clk */
			pruss1_mii_rt: mii-rt@32000 {
				compatible = "ti,pruss-mii", "syscon";
				reg = <0x32000 0x58>;
			pruss1_intc: interrupt-controller@20000 {
				compatible = "ti,pruss-intc";
				reg = <0x20000 0x2000>;
				interrupt-controller;
				#interrupt-cells = <3>;
				interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
				interrupt-names = "host_intr0", "host_intr1",
						  "host_intr2", "host_intr3",
						  "host_intr4", "host_intr5",
						  "host_intr6", "host_intr7";
			pru1_0: pru@34000 {
				compatible = "ti,am5728-pru";
				reg = <0x34000 0x3000>,
				      <0x22000 0x400>,
				      <0x22400 0x100>;
				reg-names = "iram", "control", "debug";
				firmware-name = "am57xx-pru1_0-fw";
			pru1_1: pru@38000 {
				reg = <0x38000 0x3000>,
				      <0x24000 0x400>,
				      <0x24400 0x100>;
				firmware-name = "am57xx-pru1_1-fw";
			pruss1_mdio: mdio@32400 {
				compatible = "ti,davinci_mdio";
				#size-cells = <0>;
				clocks = <&dpll_gmac_h13x2_ck>;
				bus_freq = <1000000>;
				reg = <0x32400 0x90>;
	pruss2_tm: target-module@4b2a6000 {
		reg = <0x4b2a6000 0x4>,
		      <0x4b2a6004 0x4>;
				<SYSC_IDLE_NO>,
				<SYSC_IDLE_SMART>;
				<SYSC_IDLE_NO>,
				<SYSC_IDLE_SMART>;
		clocks = <&l4per2_clkctrl DRA7_L4PER2_PRUSS2_CLKCTRL 0>;
		#size-cells = <1>;
		ranges = <0x00000000 0x4b280000 0x80000>;
		pruss2: pruss@0 {
			#size-cells = <1>;
			ranges;
			pruss2_mem: memories@0 {
				reg = <0x0 0x2000>,
				      <0x2000 0x2000>,
				      <0x10000 0x8000>;
					    "shrdram2";
			pruss2_cfg: cfg@26000 {
				#size-cells = <1>;
				clocks {
					#size-cells = <0>;
					pruss2_iepclk_mux: iepclk-mux@30 {
						reg = <0x30>;
						#clock-cells = <0>;
			pruss2_mii_rt: mii-rt@32000 {
			pruss2_intc: interrupt-controller@20000 {
				interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
			pru2_0: pru@34000 {
				      <0x22000 0x400>,
				      <0x22400 0x100>;
				firmware-name = "am57xx-pru2_0-fw";
			pru2_1: pru@38000 {
				      <0x24000 0x400>,
				      <0x24400 0x100>;
				firmware-name = "am57xx-pru2_1-fw";
			pruss2_mdio: mdio@32400 {
				#size-cells = <0>;
I am not finding anything similar on the BBB side of things with the am335x. See here:
  1. I do not know if I need something similar on the am335x to get supported access to the PRUSS.
  2. Are the newer open-pru examples ever going to be geared towards the am335x?
  3. And even if there will be examples, do you think the GPIO examples may become available?
I am still just learning about DTS files and learning how to interpret them correctly while building them with the device-tree-compiler.
Hey. How did you get kernel version 6 on the am57xx?
apt search bbb.io-kernel-* and then pick your kernel, apply it with sudo apt install YOUR_KERNEL, and reboot.
