I am looking into the possibility to port Google Android on
beagle/OMAP35x-based systems. I found this page http://elinux.org/Android_on_OMAP where it explained that there might
be complications on TLS of ARM cortex. A user report link was there
quoting not-so-successful. Meanwhile I learned that in Boston there
will be a demo soon showing Android on beagle
(http://www.cmp-egevents.com/web/escb/beagleboard). If possible, could
anyone give any hints/suggestions on this topic? It'd be great if
someone could share some experience actually porting Android to
OMAP35x.
OMAP35x.
Re-read the mail, much sorry about the confusion the newbie created earlier...
I'd like to see if one can boot up android on omap35x hardware. I read http://elinux.org/Android_on_OMAP, my understanding is that kernel
source + patch + a proper FS would do, though not sure about the TLS
issue. Would like to poll if there's a work-around for that, or any
experience regarding making android run on beagle.
I've already ported the android kernel to beagleboard(2.6.22) with
full android kernel m5_rc20 patches,
and I can boot from android emulator with appropriate kernel config
(goldfish and qemu). I think this steps
will make sure the kernel is okay. But now, I have some problem with
android file system.
I do the following test (refer to "Android on OMAP" article):
1. boot from the startard file system(ext2) of beagle board and switch
the control to android system.
I meet "segmemntation fault" while executing the "/init" command.
2. apply yaffs2 file system on /dev/mtdblock4, and copy the android's
stuff to it. After that,
modify the boot argument (root=/dev/mtdblock4 rootfstype=yaffs2
init=/init ...), but the boot procedure
stop at the following point.
<6>yaffs: dev is 32505860 name is "mtdblock4"
<6>yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.4, "mtdblock4"
VFS: Mounted root (yaffs2 filesystem).
<6>Freeing init memory: 132K
it seems to be the "/init" issue as well. (I make sure that I can
beagleboard file system on yaffs2)
I have no idea about it, and i can't go on. any suggestion is
applicated.
applicated.
We have successfully ported (custom) open source Android to beagle
board. This is very initial version. We have tested it on MMC card
and on NFS.
Please find below link for uImage and root filesystem.
and on NFS.
I just got Android running (Yay!), but also cannot use my mouse and
keyboard. In your working demo, do you have mouse and keyboard
working or do you use another form or input device?
Android does not have support for mouse. It supports only keyboard, touchscreen and trackball.
Besides I did not find any code in Android for handling mouse device events and mouse cursor.
Just found out that you can use a usb mouse as 5-way joystick rather than as a “Mouse device”. There will not be any mouse cursor. You just need to change the permission of the event node for the mouse device. You can move the move the mouse gently in all directions as well as left-click as “select”
did you install annother OS prior to Android?
- Have keyboard and mouse be working then?
I've been able to use the USB keyboard and mouse on Angstrom quite
well
Then can I use the keyboard arrows (or other keys) for navigation?
What sort of touchscreens are supported? Do you know if the USB
touchscreen that is built into the Lilliput screens (http://bit.ly/
Mg2F) would work?
