I am trying to bootup the beagleboard rev C4 with Android 2.2 (Froyo).
Source Code Base : http://code.google.com/p/rowboat/wiki/Source?tm=4
The SD card is partitioned into 2 : FAT and EXT3
Contents of FAT Partition : uImage, boot.scr, MLO, u-boot.bin and x-load.bin.ift
Contents of EXT3 partition: Root Filesysystem
Now I am facing seriuos issue in booting the kernel.
Everytime i get this :
EXT3 FS on mmcblk0p2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 144K
Warning: unable to open an initial console.
Kernel panic - not syncing: Attempted to kill init!
uBoot params:
setenv bootargs console=ttyS2,115200n8 noinitrd root=/dev/mmcblk0p2 video=omapfb.mode=dvi:1280x720MR-24@50 init=/init rootfstype=ext3 rw rootdelay=1 nohz=off androidboot.console=ttyS2
If someone has faced the same issue pls do let me know …
Finally minicom logs:
Texas Instruments X-Loader 1.4.4ss (Jul 28 2010 - 16:59:13)
Beagle Rev C4
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.06-rc2-00003-gc06326c (May 19 2009 - 15:14:43)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #613c0004000000000403730515009019
Hit any key to stop autoboot: 3 2 1 0
mmc1 is available
reading boot.scr
1944 bytes read
Running bootscript from mmc …
Executing script at 82000000
word at 0x81000000 (0x424d0074) != word at 0x48002914 (0x12336621)
Total of 0 words were the same
reading tftp-kernel.bin
** Unable to read “tftp-kernel.bin” from mmc 0:1 **
reading tftp-initrd.bin
** Unable to read “tftp-initrd.bin” from mmc 0:1 **
Wrong Image Format for bootm command
ERROR: can’t get kernel image!
OMAP3 beagleboard.org #
OMAP3 beagleboard.org # setenv bootargs console=ttyS2,115200n8 noinitrd root=/dev/mmcblk0p2 video=omapfb.mode=dvi:1280x720MR-24@50 init=/init rootfstype=ext3 rw rootdelay=1 nohz=off androidboot.console=ttyS2
OMAP3 beagleboard.org # fatload mmc 0 80300000 uImage
reading uImage
1913672 bytes read
OMAP3 beagleboard.org # bootm 80300000
Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.29-omap1-07174-g7fbc41
Data Size: 1913608 Bytes = 1.8 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Linux version 2.6.29-omap1-07174-g7fbc416-dirty (flow@debian-551585G) (gcc version 4.3.2 (crosstool-NG-1.4.1) ) #1 Mon Jun 1 17:37:15 CEST 2009
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES3.1
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: console=ttyS2,115200n8 noinitrd root=/dev/mmcblk0p2 video=omapfb.mode=dvi:1280x720MR-24@50 init=/init rootfstype=ext3 rw rootdelay=1 nohz=off androidboot.console=ttyS2
Unknown boot option `androidboot.console=ttyS2’: ignoring
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 1024 (order: 10, 4096 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 243072KB available (3512K code, 686K data, 144K init)
Calibrating delay loop… 504.17 BogoMIPS (lpj=1970176)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 520 bytes
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
bio: create slab at 0
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368…375
twl4030: power (irq 373) chaining IRQs 376…383
twl4030: gpio (irq 368) chaining IRQs 384…401
regulator: VMMC1: 1850 <–> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VUSB1V5: 1500 <–> 0 mV normal standby
regulator: VUSB1V8: 1800 <–> 0 mV normal standby
regulator: VUSB3V1: 3100 <–> 0 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VSIM: 1800 <–> 3000 mV normal standby
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
SCSI subsystem initialized
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 475
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
i2c /dev entries driver
Driver ‘sd’ needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on “omap2-nand”:
0x000000000000-0x000000080000 : “X-Loader”
0x000000080000-0x000000260000 : “U-Boot”
0x000000260000-0x000000280000 : “U-Boot Env”
0x000000280000-0x000000680000 : “Kernel”
0x000000680000-0x000010000000 : “File System”
usbmon: debugfs is not available
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.29-omap1-07174-g7fbc416-dirty ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver…
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc twl4030_rtc: Power up reset detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
logger: created 64K log ‘log_main’
logger: created 256K log ‘log_events’
logger: created 64K log ‘log_radio’
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
Console: switching to colour frame buffer device 80x30
clock: clksel_round_rate_div: dpll4_m4_ck target_rate 36000000
clock: new_div = 12, new_rate = 36000000
omapdss: Could not find exact pixel clock. Requested 23500 kHz, got 24000 kHz
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
Waiting 1sec before mounting root device…
mmc0: new SDHC card at address e624
mmcblk0: mmc0:e624 SU04G 3.69 GiB
mmcblk0: p1 p2
kjournald starting. Commit interval 5 seconds
rgds,
som
