Thanks Deva…
I downloaded sources from Embinux for android… I was able to build kernel images and Android Images but I am facing kernel panic issues…, though I give command line arguments as below;
“setenv console ttyS0 115200n8 noinitrd root=/dev/mmcblk0p2 video=omapfb.mode=dvi:1280x720MR-24@50 init=/init rootfstype=ext3 rw rootwait nohz=off androidboot.console=ttyS0”
It is taking default kernel command line arguments inbuilt in kernel which I noticed while booting… I disabled or removed inbuilt command line kernel booting parameters, then it didnt even boot ! it stopped after unzipping kernel…
Default kernel boot parameters as seen while booting screen shot;
-------------------------------------------------------- Kernel boot parameters as seen ---------------------------------------------------------------------------
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=/dev/nfs nfsroot=192.168.0.1:/home/user/buildroot ip=1
92.168.0.2:192.168.0.1:192.168.0.1:255.255.255.0:tgt:eth0:off rw console=ttyS2,1
15200n8
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
