I’m not sure how can I verify it.
Below is the log I obtain on the beagle serial port during boot:
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
607 bytes read in 17 ms (34.2 KiB/s)
Running uenvcmd …
reading zImage
5526008 bytes read in 665 ms (7.9 MiB/s)
reading am335x-boneblack.dtb
25926 bytes read in 9 ms (2.7 MiB/s)
Flattened Device Tree blob at 815f0000
Booting using the fdt blob at 0x815f0000
Using Device Tree in place at 815f0000, end 815f9545
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone54.1 (casid@casid-Latitude-D630) (gcc version 4.7.3 20130328 (prerelease) (crosstoo4
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d14000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: consoleblank=0 console=ttyO0,115200n8 androidboot.console=ttyO0 mem=512M root=/dev/mmcb0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 508372k/508372k available, 15916k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07c50cc (7925 kB)
[ 0.000000] .init : 0xc07c6000 - 0xc0802700 ( 242 kB)
[ 0.000000] .data : 0xc0804000 - 0xc088bc20 ( 544 kB)
[ 0.000000] .bss : 0xc088bc20 - 0xc0903400 ( 478 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000348] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015443] pid_max: default: 32768 minimum: 301
[ 0.015660] Security Framework initialized
[ 0.015750] Mount-cache hash table entries: 512
[ 0.025361] Initializing cgroup subsys cpuacct
[ 0.025393] Initializing cgroup subsys memory
[ 0.025455] Initializing cgroup subsys blkio
[ 0.025584] CPU: Testing write buffer coherency: ok
[ 0.026107] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026182] Setting up static identity map for 0x804a8a78 - 0x804a8ac4
[ 0.027698] Brought up 1 CPUs
[ 0.027722] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.028826] devtmpfs: initialized
[ 0.093417] pinctrl core: initialized pinctrl subsystem
[ 0.093680] rstctl core: initialized rstctl subsystem
[ 0.094146] regulator-dummy: no parameters
[ 0.094639] NET: Registered protocol family 16
[ 0.095710] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.105711] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.106644] platform 49000000.edma: alias fck already exists
[ 0.106673] platform 49000000.edma: alias fck already exists
[ 0.106697] platform 49000000.edma: alias fck already exists
[ 0.107909] OMAP GPIO hardware version 0.1
[ 0.112067] gpio-rctrl rstctl.4: loaded OK
[ 0.117430] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.119522] cpsw.0: No hwaddr in dt. Using 90:59:af:49:d2:c1 from efuse
[ 0.119552] cpsw.1: No hwaddr in dt. Using 90:59:af:49:d2:c3 from efuse
[ 0.135330] bio: create slab at 0
[ 0.146331] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.146752] vmmcsd_fixed: 3300 mV
[ 0.149355] SCSI subsystem initialized
[ 0.149745] usbcore: registered new interface driver usbfs
[ 0.149859] usbcore: registered new interface driver hub
[ 0.150134] usbcore: registered new device driver usb
[ 0.152053] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.153462] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.155617] DCDC1: at 1500 mV
[ 0.156785] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.157855] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.158961] LDO1: at 1800 mV
[ 0.160043] LDO2: at 3300 mV
[ 0.161959] LDO3: 1800 mV
[ 0.163027] LDO4: at 3300 mV
[ 0.164001] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.164701] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.165364] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.167603] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.167877] media: Linux media interface: v0.10
[ 0.167982] Linux video capture interface: v2.00
[ 0.168094] pps_core: LinuxPPS API ver. 1 registered
[ 0.168771] Advanced Linux Sound Architecture Driver Initialized.
[ 0.169711] NetLabel: Initializing
[ 0.169779] NetLabel: domain hash size = 128
[ 0.169791] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.169900] NetLabel: unlabeled traffic allowed by default
[ 0.170363] Switching to clocksource gp_timer
[ 0.222335] NET: Registered protocol family 2
[ 0.223401] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.223541] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.223709] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.223802] TCP: reno registered
[ 0.223827] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.223869] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.224247] NET: Registered protocol family 1
[ 0.224802] RPC: Registered named UNIX socket transport module.
[ 0.224820] RPC: Registered udp transport module.
[ 0.224832] RPC: Registered tcp transport module.
[ 0.224844] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.225856] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.226238] CPU PMU: attempt to register multiple PMU devices!
[ 0.226273] arm-pmu: probe of arm-pmu failed with error -28
[ 0.226681] omap2_mbox_probe: platform not supported
[ 0.494448] VFS: Disk quotas dquot_6.5.2
[ 0.494775] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.495963] NFS: Registering the id_resolver key type
[ 0.496116] Key type id_resolver registered
[ 0.496133] Key type id_legacy registered
[ 0.496537] fuse init (API version 7.20)
[ 0.497301] Btrfs loaded
[ 0.497460] msgmni has been set to 992
[ 0.500074] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.500098] io scheduler noop registered
[ 0.500112] io scheduler deadline registered
[ 0.500150] io scheduler cfq registered (default)
[ 0.502050] tps65217-bl tps65217-bl: no platform data provided
[ 0.502089] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.502956] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.505362] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.505652] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 1.254061] console [ttyO0] enabled
[ 1.258795] [drm] Initialized drm 1.1.0 20060810
[ 1.276332] brd: module loaded
[ 1.286036] loop: module loaded
[ 1.289463] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.296759] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.304033] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.311301] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.318573] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.332904] bone-capemgr bone_capemgr.9: Baseboard: ‘A335BNLT,0A5C,2713BBBK0865’
[ 1.340685] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.379462] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.416567] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.453677] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.490786] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.497043] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.503641] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.511666] bone-capemgr bone_capemgr.9: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.521809] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.528401] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.536439] bone-capemgr bone_capemgr.9: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.546492] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.553087] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.561124] bone-capemgr bone_capemgr.9: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.571712] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.580609] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.589481] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.598236] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.606939] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.612538] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.621388] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.632917] OneNAND driver initializing
[ 1.638405] usbcore: registered new interface driver cdc_ether
[ 1.644576] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.653361] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.662114] usbcore: registered new interface driver rndis_host
[ 1.668397] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.677273] usbcore: registered new interface driver cdc_ncm
[ 1.683248] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-’
[ 1.697591] usbcore: registered new interface driver cdc_acm
[ 1.703556] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.711947] Initializing USB Mass Storage driver…
[ 1.717098] bone-capemgr bone_capemgr.9: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.727795] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bo’
[ 1.742179] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.748336] usbcore: registered new interface driver usb-storage
[ 1.754644] USB Mass Storage support registered.
[ 1.760395] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.767257] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.775962] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.784751] bone-capemgr bone_capemgr.9: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[ 1.796166] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.802864] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.808101] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.817814] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 1.826132] platform 4830e000.fb: alias fck already exists
[ 1.832208] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.837294] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.844102] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 1.851013] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.859636] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.869093] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.874345] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.883219] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.892032] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘B’
[ 1.906536] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.911604] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.916931] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.923339] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.931629] bone-capemgr bone_capemgr.9: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[ 1.943168] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.950306] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.957887] usb usb1: Product: MUSB HDRC host driver
[ 1.963104] usb usb1: Manufacturer: Linux 3.8.13-bone54.1 musb-hcd
[ 1.969589] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.975116] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.984691] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.991460] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 2.002314] hub 1-0:1.0: USB hub found
[ 2.006596] hub 1-0:1.0: 1 port detected
[ 2.011515] g_ffs: file system registered
[ 2.016419] mousedev: PS/2 mouse device common for all mice
[ 2.024628] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 2.032387] i2c /dev entries driver
[ 2.037784] pps_ldisc: PPS line discipline registered
[ 2.043233] Driver for 1-wire Dallas network protocol.
[ 2.050406] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.058284] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 2.067243] cpuidle: using governor ladder
[ 2.071595] cpuidle: using governor menu
[ 2.076203] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 2.083424] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 2.090232] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 2.097433] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 2.104776] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 2.111698] omap_hsmmc mmc.5: pins are not configured from the driver
[ 2.145425] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 2.151617] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 2.159606] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 2.166067] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 2.173214] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 2.180718] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 2.187813] omap_hsmmc mmc.11: pins are not configured from the driver
[ 2.221748] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-led8
[ 2.233444] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 2.240762] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 2.249733] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 2.258197] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.265017] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 2.272245] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.280249] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.286583] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 2.293976] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 2.306664] usbcore: registered new interface driver usbhid
[ 2.312610] usbhid: USB HID core driver
[ 2.317962] ashmem: initialized
[ 2.321384] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.330284] logger: created 256K log ‘log_main’
[ 2.335446] logger: created 256K log ‘log_events’
[ 2.340554] mmc0: new high speed SDHC card at address aaaa
[ 2.346693] logger: created 256K log ‘log_radio’
[ 2.352258] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[ 2.357283] logger: created 256K log ‘log_system’
[ 2.364260] mmcblk0: p1 p2 p3 p4
[ 2.372928] davinci_evm sound.14: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 2.384131] TCP: cubic registered
[ 2.387801] NET: Registered protocol family 10
[ 2.394003] NET: Registered protocol family 17
[ 2.399058] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 2.406257] Key type dns_resolver registered
[ 2.411231] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.419482] ThumbEE CPU extension supported.
[ 2.424059] Registering SWP/SWPB emulation handler
[ 2.430301] registered taskstats version 1
[ 2.436900] tilcdc 4830e000.fb: No power control GPIO
[ 2.472836] mmc1: BKOPS_EN bit is not set
[ 2.479815] mmc1: new high speed MMC card at address 0001
[ 2.486251] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 2.491375] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 2.498197] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 2.506521] mmcblk1: p1 p2
[ 2.512153] mmcblk1boot1: unknown partition table
[ 2.519239] mmcblk1boot0: unknown partition table
[ 2.543892] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.550939] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.558426] usb 1-1: Product: USB 2.0 Hub
[ 2.563808] hub 1-1:1.0: USB hub found
[ 2.567953] hub 1-1:1.0: 4 ports detected
[ 2.574893] tilcdc 4830e000.fb: found TDA19988
[ 2.580491] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.587440] [drm] No driver support for vblank timestamp query.
[ 2.682336] Console: switching to colour frame buffer device 160x64
[ 2.706387] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.712059] tilcdc 4830e000.fb: registered panic notifier
[ 2.717834] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.774031] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.780437] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.788000] libphy: 4a101000.mdio: probed
[ 2.792264] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.802117] Detected MACID = 90:59:af:49:d2:c1
[ 2.806774] cpsw 4a100000.ethernet: NAPI disabled
[ 2.813707] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.875531] tilcdc 4830e000.fb: timeout waiting for framedone
[ 2.893375] ALSA device list:
[ 2.896518] #0: TI BeagleBone Black
[ 2.920541] usb 1-1.3: new low-speed USB device number 3 using musb-hdrc
[ 3.025972] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c05a
[ 3.033184] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.040829] usb 1-1.3: Product: USB Optical Mouse
[ 3.045745] usb 1-1.3: Manufacturer: Logitech
[ 3.054374] input: Logitech USB Optical Mouse as /devices/ocp.3/47400000.usb/musb-hdrc.1.auto/usb1/1-1/1-1.3/1-1.3:1.0/i1
[ 3.067290] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-musb0
[ 3.089745] EXT4-fs (mmcblk0p2): recovery complete
[ 3.096872] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.105378] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.113101] devtmpfs: mounted
[ 3.116541] Freeing init memory: 240K
[ 3.141714] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.254752] init: cannot open ‘/initlogo.rle’
[ 3.452405] EXT4-fs (mmcblk0p3): recovery complete
[ 3.459509] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 3.497261] init: cannot find ‘/system/bin/sgx/rc.pvr’, disabling ‘pvr’
[ 3.512066] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.562542] g_ffs: read descriptors
[ 3.566311] g_ffs: read strings
[ 3.569924] gadget: using random self ethernet address
[ 3.575473] gadget: using random host ethernet address
[ 3.582839] usb0: MAC ce:ed:c7:4a:a7:c9
[ 3.586918] usb0: HOST MAC 36:f8:9d:f3:17:dc
[ 3.591684] gadget: g_ffs ready
[ 3.595895] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 3.602672] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 3.611468] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.618622] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.626164] usb usb2: Product: MUSB HDRC host driver
[ 3.631355] usb usb2: Manufacturer: Linux 3.8.13-bone54.1 musb-hcd
[ 3.637818] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 3.645171] hub 2-0:1.0: USB hub found
[ 3.649143] hub 2-0:1.0: 1 port detected
[ 3.835113] CAUTION: musb: Babble Interrupt Occurred
root@android:/ # [ 3.950378] CAUTION: musb: Babble Interrupt Occurred
[ 4.078787] gadget: high-speed config #2: FunctionFS + ECM
It shows gadget looks to be ready.
Executing lsusb I got following info:
Bus 002 Device 021: ID 1d6b:0105 Linux Foundation FunctionFS Gadget
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 003: ID 0b97:7772 O2 Micro, Inc. OZ776 CCID Smartcard Reader
Bus 007 Device 002: ID 0b97:7761 O2 Micro, Inc. Oz776 1.1 Hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 0461:4d81 Primax Electronics, Ltd Dell N889 Optical Mouse
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
While dmesg gives:
[72049.880261] usb 2-2: new high-speed USB device number 22 using ehci-pci
[72050.014184] usb 2-2: New USB device found, idVendor=1d6b, idProduct=0105
[72050.014197] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[72050.014205] usb 2-2: Product: USB Function Filesystem
[72050.014212] usb 2-2: Manufacturer: Linux 3.8.13-bone54.1 with musb-hdrc
I added the line “g_ffs.idVendor=0x1d6b g_ffs.idProduct=0x0105 g_ffs.iSerialNumber=” to the uEnv.txt file.
Updated init.am335xevm.usb.rc file as described in your blog.
Also added “SUBSYSTEM==“usb”, ATTRS{idVendor}==“1d6b”, ATTRS{idProduct}==“0105”, MODE=“0660” GROUP=“androiddev”, SYMLINK+=“android%n”” to /etc/udev/rules.d/51-android.rules file.
But still no success, the beagleboard doesn’t appears in the listed devices under adb.
Jeremy.
