Android running on BBB with Linux 3.8
Andrew,
Thank you. I finally got both key mapping and navigation bar issue resolve.
Cheers
Mahendra
I’ve downloaded the image and using DD I have applied in my microSD.
After DD finished, my microSD mounted 3 partitions.
I’ve put it my BeagleBone Black but the android did not start (even with the boot button pressed).
I don’t know what was wrong.
Hi Daniel,
Did you ever resolve this issue? I am using the latest BBBAndroid image and my BBB is not being recognized via ADB miniusb. If I use an older image with Kernel 3.2 support I can adb shell into the BBB successfully.
Thanks!
Hi Andrew,
Its great work!! . I have an issue with the pre-built images with the custom board(duplication of BBB), while booting the system hangs at andriod boot image, i have the logcat “http://pastebin.com/ZVhQW3CC” . I cannot find which one is causing the device to hang. And i can get my LCD of resolution 320X480 working. Any idea?
I can’t get the source code from this link “repo init -u git://gitorious.org/rowboat/manifest.git -m rowboat-jb-am335x.xml”. Is there any mirror site to fetch the source code.
Could you share how?
