I have been trying to set up an Angstrom system so it is possible to connect to it using VNC, but without any luck. I have found lots of suggestions to how this should be done, but none detailing a success. The working setups all seem to use Ubuntu.
Does anyone have a step-by-step guide to this?
This is what I have done:
I have used this image:
Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.05-beaglebone-2012.05.09.img.xz
And installed
x11vnc
angstrom-x11vnc-init
If I then run
x11vnc -create
I see:
13/06/2012 09:42:17 x11vnc version: 0.9.13 lastmod: 2011-08-10 pid: 373
13/06/2012 09:42:17
13/06/2012 09:42:17 wait_for_client: WAIT:cmd=FINDCREATEDISPLAY-Xvfb
13/06/2012 09:42:17
13/06/2012 09:42:17 initialize_screen: fb_depth/fb_bpp/fb_Bpl 24/32/2560
13/06/2012 09:42:17
13/06/2012 09:42:17 Autoprobing TCP port
13/06/2012 09:42:17 Autoprobing selected port 5900
13/06/2012 09:42:17 Listening also on IPv6 port 5900 (socket 4)
13/06/2012 09:42:17
The VNC desktop is: beaglebone:0
PORT=5900
So far so good…
But when I try to connect, I get the following error:
13/06/2012 09:44:33 Got connection from client 10.10.130.103
13/06/2012 09:44:33 other clients:
13/06/2012 09:44:33 incr accepted_client=1 for 10.10.130.103:58782 sock=5
13/06/2012 09:44:33 wait_for_client: got client
13/06/2012 09:44:33 Client Protocol Version 3.8
13/06/2012 09:44:33 Protocol version sent 3.8, using 3.8
13/06/2012 09:44:33 client progressed=1 in 0/3 0.000794 s
13/06/2012 09:44:33 client useCopyRect: 10.10.130.103 0
13/06/2012 09:44:33 client_set_net: 10.10.130.103 0.0076
13/06/2012 09:44:33 wait_for_client: running: env X11VNC_SKIP_DISPLAY=’’ /bin/sh /tmp/x11vnc-find_display.fBuPef
The program “Xvfb” could not be found in PATH and standard locations.
You probably need to install a package that provides the “Xvfb” program.
Without it FINDCREATEDISPLAY mode may not be able to create an X display.
xauth: file /home/root/.Xauthority does not exist
13/06/2012 09:44:34 wait_for_client: find display cmd failed.
13/06/2012 09:44:34 wait_for_client: FINDCREATEDISPLAY cmd: /bin/sh /tmp/x11vnc-find_display.fBuPef Xvfb
trying N=20 …
13/06/2012 09:44:36 wait_for_client: read failed: /bin/sh /tmp/x11vnc-find_display.fBuPef Xvfb
13/06/2012 09:44:36 fgets: Bad file descriptor
Unfortunately there is no Xvfb package available for the beaglebone if I search for xvfb: opkg update ; opkg list | grep xvfb
If I check the feed browser at http://www.angstrom-distribution.org, I can find xserver-xorg-xvfb for arm7a architectures, but not for v2012.05 eglibc
