Problem is that when I enter the bootcmds:
setenv bootargs 'console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw
rootwait video=omapfb:mode:1024x768@60 '
setenv bootcmd 'mmc init;fatload mmc 0 80300000 uImage;bootm 80300000'
I get a low res desktop (I think 640x480)
Also, I had to change the command in the tutorials which said use
mmcinit. When I used mmcinit on this version of u-boot.bin it threw an
error.. so I am not sure if changing that to 'mmc init' is an ok thing
to do or not?
I need to be able to go up to 720p on a big HD Screen.
Another noob question, trying to move from Debian to Angstrom.
I am using the latest test image and MLO, u-boot.bin and uImage fromhttp://www.angstrom-distribution.org/demo/beagleboard/
I have the video setting as
omapfb.video_mode=800x600MR-16@60
Perhaps try this format? I think that possibly your settings are for
DSS1 but from my knowledge the newer versions of Angstrom use DSS2
What are your settings that are actually in Angstrom aka in xorg.conf,
I'm not completely sure but I think it will use the resolution you
give it to boot up but once you are in Angstrom is overriding this
with the local setting.
to do or not?
Some versions of U-boot have slightly different syntax, I'm not sure
which is the newer version but yes it was ok for you to make this
change.
I also have resolution issues when running the demo image with
matchbox desktop and
enlightenment window manager. I also get a few GTK errors which start
with "Clearlooks
configuration... is not supported" I don't remember the details
exactly.
I'm using a Dell 2007WFP monitor with an optimum resoultion of
1680x1050 @60 Hz
but my bootargs are the same as Chris's.
How exactly should I configure xorg.conf ? The last time I messed
around with it my screen
went black...I'd appreciate an example that someone has working...
with "Clearlooks
exactly.
this should be harmless, I guess its a compatibility issue with latest GTK. It
might be a good idea to update the theme or just to drop it since the default
theme has improved over the years.
