DEmo Image on C4 while booting says Kernel-Panic-not synching
Since upgrarding UBoot and Xloader to the ones required by UBUNTu my terminal ouput is too unreadable to send in email
I followed these steps
To initialize your card under Windows, you can do the following:
Download and install Ubuntu's Win32DiskImager (also known as the win32-image-writer).
Download and install 7-zip compression software.
Download the BeagleBoard verification SD card image file. (Alternatively, you can download the demo image file.)
Decompress the verification image file using 7-zip.
Insert the SD card writer/reader into the Windows machine.
Insert >=128MB SD card into the reader/writer. (If you are using the demo image file you will need an SD card of 4GB or greater)
Start the Win32DiskImager.
Select the decompressed verification image file and correct SD card location.
Click on 'Write'.
After the image writing is done, eject the SD card.
Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 - 02:49:27)
Beagle Rev C4
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Aug 20 2010 - 20:50:46)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max clock-720Mhz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a harmless I2C er
ror.
timed out in wait_for_pin: I2C_STAT=0
I2C read: I/O error
Unrecognized expansion board: 0
Beagle Rev C4
Die ID #6faa00040000000004037d070b019018
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
687 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
mmc1 is available
reading uImage
3190568 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3190504 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................
................................................................... done, bootin
g the kernel.
[ 0.000000] Linux version 2.6.32 (ubuntu@ip-10-204-115-71) (gcc version 4.3.3
(GCC) ) #3 PREEMPT Wed Aug 18 15:53:03 UTC 2010
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction ca
che
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 52736
[ 0.000000] Kernel command line: console=ttyS2,115200n8 mem=80M@0x80000000 me
m=128M@0x88000000 musb_hdrc.fifomode=5 mpurate=720 buddy=unknown camera=lbcm3m1
vram=16M omapfb.vram=0:8M,1:4M,2:4M omapfb.mode=dvi:hd720 omapdss.def_disp=dvi r
oot=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Beagle expansionboard: unknown
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 80MB 128MB = 208MB total
[ 0.000000] Memory: 187520KB available (5880K code, 671K data, 204K init, 0K
highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupt
s
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 493.67 BogoMIPS (lpj=1929216)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] Target VDD1 OPP = 6, VDD2 OPP = 3
[ 19.956054] OMAP DMA hardware revision 4.0
[ 19.965026] bio: create slab <bio-0> at 0
[ 19.966644] SCSI subsystem initialized
[ 19.968414] usbcore: registered new interface driver usbfs
[ 19.968627] usbcore: registered new interface driver hub
[ 19.968872] usbcore: registered new device driver usb
[ 19.969329] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 19.972503] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 19.972534] twl4030: power (irq 373) chaining IRQs 376..383
[ 19.972930] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 19.974578] regulator: VUSB1V5: 1500 mV normal standby
[ 19.974884] regulator: VUSB1V8: 1800 mV normal standby
[ 19.975189] regulator: VUSB3V1: 3100 mV normal standby
[ 19.979431] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 19.979949] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 19.980316] regulator: VDAC: 1800 mV normal standby
[ 19.980621] regulator: VPLL2: 1800 mV normal standby
[ 19.980987] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 19.981384] regulator: VAUX3: 1800 mV normal standby
[ 19.981811] regulator: VAUX4: 1800 mV normal standby
[ 19.994232] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 19.994628] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 19.996185] Switching to clocksource 32k_counter
[ 20.008361] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 20.008697] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 20.008728] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 20.008850] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number
1
[ 20.009033] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 20.009063] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[ 20.009063] usb usb1: Product: MUSB HDRC host driver
[ 20.009094] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 20.009094] usb usb1: SerialNumber: musb_hdrc
[ 20.009887] hub 1-0:1.0: USB hub found
[ 20.009948] hub 1-0:1.0: 1 port detected
[ 20.011291] NET: Registered protocol family 2
[ 20.011566] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 20.012390] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 20.012634] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 20.012786] TCP: Hash tables configured (established 8192 bind 8192)
[ 20.012786] TCP reno registered
[ 20.012817] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 20.012847] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 20.013153] NET: Registered protocol family 1
[ 20.013702] RPC: Registered udp transport module.
[ 20.013732] RPC: Registered tcp transport module.
[ 20.013732] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 20.014892] omap-iommu omap-iommu.0: isp registered
[ 20.017028] VFS: Disk quotas dquot_6.5.2
[ 20.017150] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 20.018493] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 20.019531] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 20.020660] msgmni has been set to 366
[ 20.026031] alg: No test for stdrng (krng)
[ 20.026367] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
54)
[ 20.026397] io scheduler noop registered
[ 20.026428] io scheduler deadline registered
[ 20.026611] io scheduler cfq registered (default)
[ 20.082519] OMAP DSS rev 2.0
[ 20.082580] OMAP DISPC rev 3.0
[ 20.082641] OMAP VENC rev 2
[ 20.082946] OMAP DSI rev 1.0
[ 20.423156] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 20.444488] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 20.464904] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 20.485351] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 21.054382] console [ttyS2] enabled
[ 21.067047] brd: module loaded
[ 21.074554] loop: module loaded
[ 21.079254] omap2-nand driver initializing
[ 21.083740] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 25
6MiB 1,8V 16-bit)
[ 21.092987] cmdlinepart partition parsing not available
[ 21.098297] Creating 5 MTD partitions on "omap2-nand":
[ 21.103485] 0x000000000000-0x000000080000 : "X-Loader"
[ 21.110168] 0x000000080000-0x000000260000 : "U-Boot"
[ 21.116912] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 21.123260] 0x000000280000-0x000000680000 : "Kernel"
[ 21.130859] 0x000000680000-0x000010000000 : "File System"
[ 21.242279] usbcore: registered new interface driver catc
[ 21.247772] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 21.253845] usbcore: registered new interface driver kaweth
[ 21.259490] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet dr
iver
[ 21.267150] usbcore: registered new interface driver pegasus
[ 21.272888] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 21.279937] usbcore: registered new interface driver rtl8150
[ 21.285797] usbcore: registered new interface driver asix
[ 21.291320] usbcore: registered new interface driver cdc_ether
[ 21.297332] usbcore: registered new interface driver dm9601
[ 21.303131] usbcore: registered new interface driver smsc95xx
[ 21.309051] usbcore: registered new interface driver gl620a
[ 21.314788] usbcore: registered new interface driver net1080
[ 21.320617] usbcore: registered new interface driver plusb
[ 21.326293] usbcore: registered new interface driver rndis_host
[ 21.332397] usbcore: registered new interface driver cdc_subset
[ 21.338439] usbcore: registered new interface driver zaurus
[ 21.344207] usbcore: registered new interface driver MOSCHIP usb-ethernet dri
ver
[ 21.352478] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 21.359436] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 21.365539] ehci-omap ehci-omap.0: new USB bus registered, assigned bus numbe
r 2
[ 21.373229] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 21.386871] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 21.392791] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 21.399688] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[ 21.407012] usb usb2: Product: OMAP-EHCI Host Controller
[ 21.412384] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 21.417816] usb usb2: SerialNumber: ehci-omap.0
[ 21.423248] hub 2-0:1.0: USB hub found
[ 21.427124] hub 2-0:1.0: 3 ports detected
[ 21.457458] Initializing USB Mass Storage driver...
[ 21.462554] usbcore: registered new interface driver usb-storage
[ 21.468658] USB Mass Storage support registered.
[ 21.473785] mice: PS/2 mouse device common for all mice
[ 21.479522] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 21.487609] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-
0049/twl4030_pwrbutton/input/input1
[ 21.498443] i2c /dev entries driver
[ 21.502777] Linux video capture interface: v2.00
[ 21.507812] omap-iommu omap-iommu.0: isp: version 1.1
[ 21.514617] vpfe_init
[ 21.517608] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 21.629638] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
[ 21.636779] Registered led device: beagleboard::usr0
[ 21.641998] Registered led device: beagleboard::usr1
[ 21.648162] Registered led device: beagleboard::pmu_stat
[ 21.656158] usbcore: registered new interface driver usbhid
[ 21.661834] usbhid: USB HID core driver
[ 21.665893] Advanced Linux Sound Architecture Driver Version 1.0.21.
[ 21.672973] usbcore: registered new interface driver snd-usb-audio
[ 21.755767] usb 2-2: new high speed USB device using ehci-omap and address 2
[ 21.765655] No device for DAI omap-mcbsp-dai-0
[ 21.770202] No device for DAI omap-mcbsp-dai-1
[ 21.774658] No device for DAI omap-mcbsp-dai-2
[ 21.779174] No device for DAI omap-mcbsp-dai-3
[ 21.783660] No device for DAI omap-mcbsp-dai-4
[ 21.788177] OMAP3 Beagle SoC init
[ 21.793365] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 21.806579] ALSA device list:
[ 21.809631] #0: omap3beagle (twl4030)
[ 21.813629] oprofile: using arm/armv7
[ 21.817626] TCP cubic registered
[ 21.820892] NET: Registered protocol family 17
[ 21.825469] NET: Registered protocol family 15
[ 21.830047] lib80211: common routines for IEEE802.11 drivers
[ 21.835815] ThumbEE CPU extension supported.
[ 21.840148] Power Management for TI OMAP3.
[ 21.845489] ------------[ cut here ]------------
[ 21.850158] WARNING: at arch/arm/mach-omap2/dpll.c:439 omap3_noncore_dpll_set
_rate+0x228/0x26c()
[ 21.859008] Modules linked in:
[ 21.862121] [<c0040c40>] (unwind_backtrace+0x0/0xdc) from [<c006cad8>] (warn_
slowpath_common+0x4c/0x80)
[ 21.871551] [<c006cad8>] (warn_slowpath_common+0x4c/0x80) from [<c004b138>] (
omap3_noncore_dpll_set_rate+0x228/0x26c)
[ 21.882232] [<c004b138>] (omap3_noncore_dpll_set_rate+0x228/0x26c) from [<c00
496ec>] (omap2_clk_set_rate+0x24/0x34)
[ 21.892730] [<c00496ec>] (omap2_clk_set_rate+0x24/0x34) from [<c0050d84>] (cl
k_set_rate+0x4c/0xac)
[ 21.901763] [<c0050d84>] (clk_set_rate+0x4c/0xac) from [<c0010c48>] (omap2_cl
k_set_freq+0x264/0x410)
[ 21.910949] [<c0010c48>] (omap2_clk_set_freq+0x264/0x410) from [<c0010748>] (
omap3_sr_init+0xe0/0x174)
[ 21.920318] [<c0010748>] (omap3_sr_init+0xe0/0x174) from [<c003b374>] (do_one
_initcall+0x5c/0x1bc)
[ 21.929321] [<c003b374>] (do_one_initcall+0x5c/0x1bc) from [<c0008414>] (kern
el_init+0xa4/0x128)
[ 21.938171] [<c0008414>] (kernel_init+0xa4/0x128) from [<c003c9dc>] (kernel_t
hread_exit+0x0/0x8)
[ 21.947021] ---[ end trace d3ff83a197f64efb ]---
[ 21.951965] Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/720 MH
z
[ 21.959259] IVA2 clocking rate: 520 MHz
[ 22.136993] SmartReflex driver initialized
[ 22.148925] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 1
[ 22.157348] registered taskstats version 1
[ 22.263702] usb 2-2: New USB device found, idVendor=05e3, idProduct=0608
[ 22.270507] usb 2-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 22.277740] usb 2-2: Product: USB2.0 Hub
[ 22.300628] Console: switching to colour frame buffer device 160x45
[ 22.328216] hub 2-2:1.0: USB hub found
[ 22.332031] Unable to handle kernel NULL pointer dereference at virtual addre
ss 00000014
[ 22.340179] pgd = c0004000
[ 22.342895] [00000014] *pgd=00000000
[ 22.346496] Internal error: Oops: 5 [#1] PREEMPT
[ 22.351135] last sysfs file:
[ 22.354125] Modules linked in:
[ 22.357208] CPU: 0 Tainted: G W (2.6.32 #3)
[ 22.362487] PC is at musb_interrupt+0x9f8/0xbb8
[ 22.367034] LR is at musb_interrupt+0x9e4/0xbb8
[ 22.371582] pc : [<c033df94>] lr : [<c033df80>] psr: 60000193
[ 22.371612] sp : cf887b78 ip : cf887bb0 fp : 000000e0
[ 22.383148] r10: 00000000 r9 : 00000099 r8 : 00000001
[ 22.388397] r7 : 00000000 r6 : cf82b108 r5 : 00000001 r4 : 00000000
[ 22.394958] r3 : 00000000 r2 : 00000000 r1 : fa0ab000 r0 : cf82b108
[ 22.401519] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment ker
nel
[ 22.408935] Control: 10c5387d Table: 80004019 DAC: 00000017
[ 22.414733] Process khubd (pid: 14, stack limit = 0xcf8862f0)
[ 22.420501] Stack: (0xcf887b78 to 0xcf888000)
[ 22.424865] 7b60: 00000
000 cf887b88
[ 22.433105] 7b80: cf8afeac cf8afeac c0667ac0 cf82b108 60000113 cf8a0900 cf886
000 0000005c
[ 22.441314] 7ba0: 00000000 00000000 c0667ac0 c033e1b8 cf886000 cf8a0900 c0635
148 c00a33a0
[ 22.449554] 7bc0: c06bbad0 cf8a0900 c0635148 0000005c 00000002 00000001 cf886
000 cf887c75
[ 22.457763] 7be0: cf887c66 c00a5498 0000005c 00000000 cf887c75 c003b074 00004
4b0 ffffffff
[ 22.466003] 7c00: fa200000 c003bb44 00000001 80000013 c0630fac c0630fac 00000
001 00000005
[ 22.474212] 7c20: cf887c75 c067da23 0000001b 00000030 cf887c75 cf887c66 cf887
c28 cf887c50
[ 22.482452] 7c40: c006d23c c006d904 60000013 ffffffff c00636d8 00000036 00000
000 80000013
[ 22.490661] 7c60: 00000035 205b7ca4 32322020 3832332e 5d363132 cf800020 00000
001 00000000
[ 22.498901] 7c80: 00000000 c06b46fc 00000000 cf886000 00000000 c0255bd0 00000
010 cfb34e20
[ 22.507110] 7ca0: cfb34e00 00000000 cfb34e20 c0653328 cfb34e00 cfa2c000 00000
000 c04838b0
[ 22.515350] 7cc0: 00000000 c031e128 c05b1c6b c05b1f9c cfb31bc0 c0653328 22222
222 22222222
[ 22.523559] 7ce0: 00000000 cfa2c318 cfb34e00 00000001 cfa2c068 cfa78cc0 cfa2c
000 c0484bb8
[ 22.531799] 7d00: cfa2c000 cfb34e20 cfb34e00 00000000 cfa2c000 c0653328 c0653
3dc c06532f8
[ 22.540008] 7d20: 00000000 c03264a0 00000000 c02babd8 cfb34e20 c0653328 00000
000 c0653468
[ 22.548248] 7d40: cfb34e28 c02baa78 cfb34e20 00000000 c02babd8 cfb34e20 cf887
d60 c02b9eb0
[ 22.556457] 7d60: cf87a808 cf87a574 c008c924 cfb34e20 cfb34e20 cfb34e54 00000
000 c02bacbc
[ 22.564697] 7d80: cfb34e00 cfb34e20 cfa2c000 c02b9ce4 00000000 c02b861c cfa2c
000 cfa2c068
[ 22.572906] 7da0: cfb34e28 00000000 00000021 c0256d04 cfa78d08 cfb34e00 cfb34
e00 cfa2c000
[ 22.581146] 7dc0: 00000000 cfb16c00 cfb16c00 00000001 cfa78d00 c0324cbc 00000
001 00000000
[ 22.589355] 7de0: 00000000 00000000 00001388 c0062044 00000000 00000001 cfa2c
c00 cfa2c004
[ 22.597595] 7e00: 00000000 cfb31c00 00000001 cfa2c068 cfb16c00 cfb16c04 00000
000 cfa2c000
[ 22.605804] 7e20: 00000001 cfa2c068 c0653b2c 00000000 c0653294 cfa2c070 00000
000 c032ce3c
[ 22.614044] 7e40: cfa2c070 c0653b2c 00000000 c02babd8 cfa2c068 c032501c cfa2c
068 c02baa78
[ 22.622253] 7e60: cfa2c068 00000000 c02babd8 cfa2c068 cf887e78 c02b9eb0 cf87a
808 cf87a4f4
[ 22.630493] 7e80: c008c924 cfa2c068 cfa2c068 cfa2c09c cfa2cc00 c02bacbc cf887
eb9 cfa2c068
[ 22.638702] 7ea0: cf81bcc0 c02b9ce4 00000000 c02b861c 00000501 cfa2c868 39383
100 3932313a
[ 22.646942] 7ec0: cfa2cc00 c031ae40 c05b15a1 00000000 cfa2c000 cfa2c068 cfa2c
c00 cfa4ce00
[ 22.655151] 7ee0: 00000501 00000002 cfa2c800 c031dc70 00000001 00000000 00000
000 cfa2cc18
[ 22.663391] 7f00: cfa2c000 c031f4b8 00000000 00000004 00007735 c06309c8 cf84a
070 c06309c8
[ 22.671600] 7f20: 00000000 cf887f94 cf886000 cfa2ca40 00000000 cf886000 00000
002 cfa3f020
[ 22.679840] 7f40: cfa3f000 cfa2c800 cfa4ce40 cfa4ce44 cfa4ce48 cfa2c89c cfa4c
e08 00000000
[ 22.688079] 7f60: cfa3f020 cfa4ce9c cfa4ce4c 00000001 00000001 00000009 cfa2c
c00 c0062044
[ 22.696289] 7f80: cfa4ce01 cfa2c804 00000000 cf84a040 c0087c10 cf887f94 cf887
f94 cf84a2d8
[ 22.704528] 7fa0: 05010000 cf887fd4 cf81ff64 cf887fd4 cf81ff64 00000000 c031e
924 00000000
[ 22.712738] 7fc0: 00000000 00000000 00000000 c00877f0 00000000 00000000 cf887
fd8 cf887fd8
[ 22.720977] 7fe0: 00000000 00000000 00000000 00000000 00000000 c003c9dc 02f7f
f00 00fffe00
[ 22.729217] [<c033df94>] (musb_interrupt+0x9f8/0xbb8) from [<c033e1b8>] (gene
ric_interrupt+0x64/0x98)
[ 22.738494] [<c033e1b8>] (generic_interrupt+0x64/0x98) from [<c00a33a0>] (han
dle_IRQ_event+0xac/0x1ec)
[ 22.747863] [<c00a33a0>] (handle_IRQ_event+0xac/0x1ec) from [<c00a5498>] (han
dle_level_irq+0xbc/0x148)
[ 22.757232] [<c00a5498>] (handle_level_irq+0xbc/0x148) from [<c003b074>] (asm
_do_IRQ+0x74/0x98)
[ 22.765991] [<c003b074>] (asm_do_IRQ+0x74/0x98) from [<c003bb44>] (__irq_svc+
0x44/0xa8)
[ 22.774047] Exception stack(0xcf887c08 to 0xcf887c50)
[ 22.779113] 7c00: 00000001 80000013 c0630fac c0630fac 00000
001 00000005
[ 22.787353] 7c20: cf887c75 c067da23 0000001b 00000030 cf887c75 cf887c66 cf887
c28 cf887c50
[ 22.795562] 7c40: c006d23c c006d904 60000013 ffffffff
[ 22.800659] [<c003bb44>] (__irq_svc+0x44/0xa8) from [<c006d904>] (vprintk+0x3
94/0x428)
[ 22.808624] [<c006d904>] (vprintk+0x394/0x428) from [<c04838b0>] (printk+0x18
/0x28)
[ 22.816345] [<c04838b0>] (printk+0x18/0x28) from [<c031e128>] (hub_probe+0xc0
/0x8bc)
[ 22.824157] [<c031e128>] (hub_probe+0xc0/0x8bc) from [<c03264a0>] (usb_probe_
interface+0x104/0x164)
[ 22.833251] [<c03264a0>] (usb_probe_interface+0x104/0x164) from [<c02baa78>]
(driver_probe_device+0xc4/0x1a0)
[ 22.843231] [<c02baa78>] (driver_probe_device+0xc4/0x1a0) from [<c02b9eb0>] (
bus_for_each_drv+0x4c/0x8c)
[ 22.852783] [<c02b9eb0>] (bus_for_each_drv+0x4c/0x8c) from [<c02bacbc>] (devi
ce_attach+0x68/0x8c)
[ 22.861694] [<c02bacbc>] (device_attach+0x68/0x8c) from [<c02b9ce4>] (bus_pro
be_device+0x28/0x50)
[ 22.870635] [<c02b9ce4>] (bus_probe_device+0x28/0x50) from [<c02b861c>] (devi
ce_add+0x368/0x508)
[ 22.879455] [<c02b861c>] (device_add+0x368/0x508) from [<c0324cbc>] (usb_set_
configuration+0x5e0/0x684)
[ 22.888916] [<c0324cbc>] (usb_set_configuration+0x5e0/0x684) from [<c032ce3c>
] (generic_probe+0x5c/0xa0)
[ 22.898437] [<c032ce3c>] (generic_probe+0x5c/0xa0) from [<c032501c>] (usb_pro
be_device+0x2c/0x34)
[ 22.907379] [<c032501c>] (usb_probe_device+0x2c/0x34) from [<c02baa78>] (driv
[ 22.916900] [<c02baa78>] (driver_probe_device+0xc4/0x1a0) from [<c02b9eb0>] (
[ 22.926452] [<c02b9eb0>] (bus_for_each_drv+0x4c/0x8c) from [<c02bacbc>] (devi
[ 22.935394] [<c02bacbc>] (device_attach+0x68/0x8c) from [<c02b9ce4>] (bus_pro
[ 22.944305] [<c02b9ce4>] (bus_probe_device+0x28/0x50) from [<c02b861c>] (devi
ce_add+0x368/0x508)
[ 22.953155] [<c02b861c>] (device_add+0x368/0x508) from [<c031dc70>] (usb_new_
device+0xe8/0x15c)
[ 22.961883] [<c031dc70>] (usb_new_device+0xe8/0x15c) from [<c031f4b8>] (hub_t
hread+0xb94/0x10d4)
[ 22.970733] [<c031f4b8>] (hub_thread+0xb94/0x10d4) from [<c00877f0>] (kthread
+0x78/0x80)
[ 22.978881] [<c00877f0>] (kthread+0x78/0x80) from [<c003c9dc>] (kernel_thread
_exit+0x0/0x8)
[ 22.987274] Code: e3530003 13a02000 05963078 05933018 (05d33014)
[ 22.993499] ---[ end trace d3ff83a197f64efd ]---
[ 22.998168] Kernel panic - not syncing: Fatal exception in interr
