After using Robert's 2.6.29 image (thx again!) I get consistent GUI
startup, bringing me to the login screen -- but it doesn't see my USB
mouse or keyboard -- at all.
The deuce of it is, it *used* to work -- could there be some setup
file that could have gone bogus, or that I could delete to start over
(other than starting from a fresh SD card)?
I checked the suggestion that it might be my (DLink, active) USB hub
by plugging a card reader into it. Angstrom (from the root login over
the UART) does indeed see and read the card (as sda1) through the hub,
as this brief log shows as I write and read data from /media/sda1/ :
root@beagleboard:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 1.8G 369.5M 1.3G 22% /
tmpfs 40.0K 0 40.0K 0% /mnt/.psplash
none 117.1M 88.0K 117.0M 0% /dev
tmpfs 117.1M 16.0K 117.1M 0% /var/volatile
tmpfs 117.1M 0 117.1M 0% /dev/shm
tmpfs 117.1M 0 117.1M 0% /media/ram
/dev/mmcblk0p2 1.8G 369.5M 1.3G 22% /media/
mmcblk0p2
/dev/mmcblk0p1 46.3M 5.6M 40.7M 12% /media/
mmcblk0p1
/dev/sda1 1.9G 0 1.9G 0% /media/sda1
root@beagleboard:~# cat > /media/sda1/junk
la la la
hi there
root@beagleboard:~# ls -l /media/sda1/junk
-rwxr-xr-x 1 root root 18 May 7 02:47 /media/sda1/junk
root@beagleboard:~# cat /media/sda1/junk
la la la
hi there
root@beagleboard:~#
Enlightenment bug? Wacky BB? EHCI failure for Rev C2? Anyone have any
ideas?
thanks
kb
