Hi
Even i have been facing the same error
Processing bitbake: Fixed to revision 7e3a99949358f4362876df5a82f8aeaae72c3c97, skipping update
Processing meta-angstrom: Current branch angstrom-v2012.12-yocto1.3 is up to date.
Processing meta-openembedded: Current branch angstrom-staging-yocto1.3 is up to date.
Processing meta-beagleboard: Current branch danny is up to date.
Processing meta-ti: Current branch angstrom-staging-yocto1.3 is up to date.
Processing meta-ettus: Fixed to revision 5a6a642f6707dc42a5210dbbf01d2bdfd869d4b0, skipping update
Processing meta-efikamx: Fixed to revision 07f2a5c777b4f866985735303bc6d696592760a9, skipping update
Processing meta-nslu2: Fixed to revision 8948458fe3ec2b3c713b2a13a87123b64e22b0d9, skipping update
Processing meta-smartphone: Current branch danny is up to date.
Processing meta-intel: Fixed to revision 98342e9e685ac8066f7fe2517fd382127a286648, skipping update
Processing meta-xilinx: Fixed to revision d196fa93c7ff5e080d4c44e2b83aed472f32b2c7, skipping update
Processing meta-openpandora: Fixed to revision bdd973321efabf9da4ac7bbc5e18ecab257841a3, skipping update
Processing meta-raspberrypi: Current branch danny is up to date.
Processing meta-handheld: Current branch danny is up to date.
Processing meta-opie: Fixed to revision c242efc6ca55772a88602f1f8f94dff697b38430, skipping update
Processing meta-java: Fixed to revision 75dee76c7cfbf1418e5c581f50bb57b3282013f7, skipping update
Processing meta-browser: Current branch angstrom-staging-yocto1.3 is up to date.
Processing meta-mono: Fixed to revision adf47f078dbf788a80ff1398a15a4fd5a334d320, skipping update
Processing meta-kde: Fixed to revision 316d9c27e72cfebc7618268f8766624ee3f5e18e, skipping update
Processing meta-linaro: Current branch danny is up to date.
Processing meta-minnow: Current branch danny is up to date.
Processing meta-allwinner: Current branch danny is up to date.
Processing meta-ros: Fixed to revision 1a6a63ef2316a45a2fa07e00907a73d33aeeb7d7, skipping update
Processing openembedded-core: Using /home/chaitra32bit/.oe/environment-angstromv2012.12 to setup needed variables. It is recommended to do ‘. /home/chaitra32bit/.oe/environment-angstromv2012.12’ and run ‘bitbake something’ without using ./oebb.sh as wrapper
Executing: MACHINE=beagleboard bitbake virtual/kernel
Loading cache…done.
Loaded 3162 entries from dependency cache.
Parsing recipes…done.
Parsing of 2649 .bb files complete (2645 cached, 4 parsed). 3168 targets, 120 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/chaitra32bit/bb/sources/meta-handheld/recipes-core/udev/udev_164.bbappend
/home/chaitra32bit/bb/sources/meta-intel/meta-fri2/recipes-core/tiny-init/tiny-init.bbappend
Build Configuration:
BB_VERSION = “1.17.0”
TARGET_ARCH = “arm”
TARGET_OS = “linux-gnueabi”
MACHINE = “beagleboard”
DISTRO = “angstrom”
DISTRO_VERSION = “v2012.12”
TUNE_FEATURES = “armv7a vfp neon cortexa8”
TARGET_FPU = “vfp-neon”
meta-angstrom = “angstrom-v2012.12-yocto1.3:b7f8207b94d9a0ece73ad212a193cb2c95bd17ee”
meta-oe
meta-systemd
meta-efl
meta-gpe
meta-gnome
meta-xfce
meta-initramfs
toolchain-layer
meta-multimedia
meta-networking
meta-webserver
meta-ruby = “angstrom-staging-yocto1.3:c24d2b6dfd00724b3182977e19a153492afe9343”
meta-kde = “master:316d9c27e72cfebc7618268f8766624ee3f5e18e”
meta-opie = “master:c242efc6ca55772a88602f1f8f94dff697b38430”
meta-java = “master:75dee76c7cfbf1418e5c581f50bb57b3282013f7”
meta-browser = “angstrom-staging-yocto1.3:011dbb273ac725e5a9e62ae36b8e538b2e9eb09c”
meta-mono = “master:adf47f078dbf788a80ff1398a15a4fd5a334d320”
meta-ros = “master:1a6a63ef2316a45a2fa07e00907a73d33aeeb7d7”
common-bsp = “danny:136a28e4d16a03ee9a5e51d6e378f1b80c618b28”
meta-ti = “angstrom-staging-yocto1.3:69132771c1332951f424beeeb54dcb70a8a73541”
meta-efikamx = “master:07f2a5c777b4f866985735303bc6d696592760a9”
meta-nslu2 = “master:8948458fe3ec2b3c713b2a13a87123b64e22b0d9”
meta-htc
meta-nokia
meta-openmoko
meta-palm = “danny:924338ee2d44987da71088da31e1cd31d3a9dfa9”
meta-handheld = “danny:d641e71a7c09cd24c72e690ad1981e49da612bcd”
meta-intel
meta-sugarbay
meta-crownbay
meta-emenlow
meta-fri2
meta-jasperforest
meta-n450 = “danny:98342e9e685ac8066f7fe2517fd382127a286648”
meta-allwinner = “danny:3603ce61c075d2f6a23dbe0bd71ee604f7eb24ea”
meta-raspberrypi = “danny:1ad98cf651054982c1a69576c1663285f0090034”
meta-minnow = “danny:182ae8dca4e29cfc9335e19a4d4c5a8511c9fcf6”
meta-linaro = “danny:e6f8003b039335f7ec75edf9a9b7a84d2d1b911a”
meta = “angstrom-staging-yocto1.3:845fa230a19c835cdb5d886b75c03df88ca30987”
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Running task 572 of 1074 (ID: 664, /home/chaitra32bit/bb/sources/openembedded-core/meta/recipes-core/eglibc/eglibc-initial_2.16.bb, do_compile)
NOTE: Running task 599 of 1074 (ID: 494, virtual:native:/home/chaitra32bit/bb/sources/openembedded-core/meta/recipes-devtools/elfutils/elfutils_0.148.bb, do_compile)
NOTE: recipe eglibc-initial-2.16-r15+svnr20393: task do_compile: Started
NOTE: recipe elfutils-native-0.148-r11: task do_compile: Started
NOTE: recipe eglibc-initial-2.16-r15+svnr20393: task do_compile: Succeeded
NOTE: Running task 600 of 1074 (ID: 660, /home/chaitra32bit/bb/sources/openembedded-core/meta/recipes-core/eglibc/eglibc-initial_2.16.bb, do_install)
ERROR: Function failed: do_compile (see /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/temp/log.do_compile.3249 for further information)
ERROR: Logfile of failure stored in: /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/temp/log.do_compile.3249
Log data follows:
DEBUG: Executing shell function do_compile
NOTE: make -j2
make all-recursive
make[1]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148' Making all in config make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/config’
make[2]: Nothing to be done for all'. make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/config’
Making all in m4
make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/m4' make[2]: Nothing to be done for all’.
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/m4' Making all in lib make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/lib’
make[2]: Nothing to be done for all'. make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/lib’
Making all in libelf
make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libelf' make[2]: Nothing to be done for all’.
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libelf' Making all in libebl make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libebl’
make[2]: Nothing to be done for all'. make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libebl’
Making all in libdwfl
make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdwfl' make[2]: Nothing to be done for all’.
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdwfl' Making all in libdw make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdw’
make all-am
make[3]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdw' make[3]: Nothing to be done for all-am’.
make[3]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdw' make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libdw’
Making all in libcpu
make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libcpu' make[2]: Nothing to be done for all’.
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libcpu' Making all in libasm make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libasm’
make[2]: Nothing to be done for all'. make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/libasm’
Making all in backends
make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/backends' make[2]: Nothing to be done for all’.
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/backends' Making all in src make[2]: Entering directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src’
gcc -D_GNU_SOURCE -DHAVE_CONFIG_H -DLOCALEDIR=‘“/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/share/locale”’ -DDEBUGPRED=0 -DSRCDIR="/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src" -DOBJDIR="/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src" -I. -I… -I. -I. -I…/lib -I… -I./…/libelf -I./…/libebl -I./…/libdw -I./…/libdwfl -I./…/libasm -isystem/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/include -std=gnu99 -Wall -Wshadow -Werror -Wunused -Wextra -fgnu89-inline -Wformat=2 -isystem/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/include -O2 -pipe -c i386_ld.c
gcc -D_GNU_SOURCE -DHAVE_CONFIG_H -DLOCALEDIR=‘“/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/share/locale”’ -DDEBUGPRED=0 -DSRCDIR="/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src" -DOBJDIR="/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src" -I. -I… -I. -I. -I…/lib -I… -I./…/libelf -I./…/libebl -I./…/libdw -I./…/libdwfl -I./…/libasm -isystem/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/include -std=gnu99 -Wall -Wshadow -Werror -Wunused -Wextra -fgnu89-inline -Wno-format -isystem/home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/sysroots/i686-linux/usr/include -O2 -pipe -c addr2line.c
addr2line.c: In function ‘handle_address’:
addr2line.c:450:7: error: format ‘%a’ expects argument of type ‘float *’, but argument 3 has type ‘char **’ [-Werror=format=]
if (sscanf (string, “(%a[^)])%” PRIiMAX “%n”, &name, &addr, &i) == 2
addr2line.c:453:7: error: format ‘%a’ expects argument of type ‘float *’, but argument 3 has type ‘char **’ [-Werror=format=]
switch (sscanf (string, “%a[^-+]%n%” PRIiMAX “%n”, &name, &i, &addr, &j))
cc1: all warnings being treated as errors
make[2]: *** [addr2line.o] Error 1
make[2]: *** Waiting for unfinished jobs…
rm i386_ld.o
make[2]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148/src' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory /home/chaitra32bit/bb/build/tmp-angstrom_v2012_12-eglibc/work/i686-linux/elfutils-native-0.148-r11/elfutils-0.148’
make: *** [all] Error 2
ERROR: oe_runmake failed
NOTE: recipe elfutils-native-0.148-r11: task do_compile: Failed
NOTE: recipe eglibc-initial-2.16-r15+svnr20393: task do_install: Started
ERROR: Task 494 (virtual:native:/home/chaitra32bit/bb/sources/openembedded-core/meta/recipes-devtools/elfutils/elfutils_0.148.bb, do_compile) failed with exit code ‘1’
NOTE: recipe eglibc-initial-2.16-r15+svnr20393: task do_install: Succeeded
NOTE: Tasks Summary: Attempted 600 tasks of which 597 didn’t need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Any solution to this problem?
