Hi all,
I am trying to boot Angstrom using the files from the link :
http://www.angstrom-distribution.org/demo/beagleboard/
In SD card (8GB) partition 1 is FAT16 (50 MB) with the files in
following order: MLO, u-boot.bin, x-load.bin.ift, uImage (for 2.6.29)
and boot.scr
SD card partition is ext3 with Angstrom kernel 2.6.29 and
modules-2.6.29-r47-beagleboard.tgz untarred.....
Now at the time when the kernel is loaded, the serial port displays
the following message and freezes forever:
[ 21.295166] Console: switching to colour frame buffer device 160x45
[ 21.313262] clock: clksel_round_rate_div: dpll4_m4_ck target_rate
48000000
[ 21.320343] clock: new_div = 9, new_rate = 48000000
[ 21.327941] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 21.334777] Waiting for root device /dev/mmcblk0p2...
[ 21.359649] mmc0: new high speed SDHC card at address 0001
[ 21.365905] mmcblk0: mmc0:0001 00000 7.60 GiB
[ 21.370819] mmcblk0: p1 p2
[ 21.447540] EXT3-fs: INFO: recovery required on readonly
filesystem.
[ 21.454162] EXT3-fs: write access will be enabled during recovery.
[ 24.451354] kjournald starting. Commit interval 5 seconds
[ 24.457122] EXT3-fs: recovery complete.
[ 24.662780] EXT3-fs: mounted filesystem with ordered data mode.
[ 24.671173] VFS: Mounted root (ext3 filesystem) readonly on device
179:2.
[ 24.680603] Freeing init memory: 204K
[ 25.225128] EXT3 FS on mmcblk0p2, internal journal
[ 25.404937] NET: Registered protocol family 10
[ 25.477203] NET: Registered protocol family 23
[ 25.500976] IrCOMM protocol (Dag Brattli)
The DVI monitor says the following message:
INIT: version 2.86 booting
Starting udev/etc/rcS.d/S03udev: line 50: cant create /tmp/uname: Read-
only file system
touch: cannot touch '/tmp/uname': Read-only file system
Remounting root file system
ALSA: Restoring mixer settings.......
Configuring network interfaces...../usr/sbin/alsact1:load_state1616:No
soundcards found....
eth0:unknown interface: No such device
done.
Startiing portmap daemon:portmapportmap:fork:No such device
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
hwclock: cant open 'dev/misc/rtc': No such file or directory
Fri Jun12 13:04:00 BST 2009
I request you guys to help me out please.........
Ramasamy Gopalan.
