Hi all,
I'm trying to have opencv for the beagleboard.
I get angstrom toolchain from http://www.angstrom-distribution.org/narcissus/
and I checked the opencv library but I can't find the library to use
so I decided to cross compile opencv.
The opecv version I use is 1.0 but 2.0 is the same.
this is the procedure I followed:
cd opencv-1.0.0
export CXX=/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-g++
. /usr/local/angstrom/arm/environment-setup
./configure --host=arm-linux --without-gtk --without-highgui --without-
v4l --without-carbon --without-quicktime --without-1394libs --without-
ffmpeg --without-python --without-swig --disable-apps
make
but I get this error:
/bin/sh ../../libtool --tag=CXX --mode=link arm-angstrom-linux-gnueabi-
g++ -Wall -fno-rtti -pipe -O3 -fomit-frame-pointer -o libcxcore.la
-rpath /usr/local/lib -no-undefined -version-info 1:0:0 dummy.lo
lib_cxcore.la -lpthread -ldl -lm
libtool: link: cannot find the library `' or unhandled argument `/'
make[3]: *** [libcxcore.la] Error 1
Can you help me?
