I’ve attached my BBone to a modem dev platform using two methods.
USB (Modem) to USB (BBone) FTDI Solution
RS232(Modem) to USBtoSerial(BBone) Prolific PL2303 Solution
Drivers for both have been installed via opkg, and both give the same
reusults, all characters are transmitted from the BBone, but only about 50% of
the characters returned are recived by the application. (See attached)
To date, I’ve tried to use ps to locate another application that might be
using my /dev/ttyUSBx port, but without success (See below)
root@beaglebone:~/tcp_serial_redirect# ps | grep
tty 238 root 1952 S /sbin/agetty tty1 38400
269 root 1772 S grep tty
usb 16 root 0 SW< [musb-hdrc.0]
17 root 0 SW< [musb-hdrc.1]
271 root 1772 S grep usb
I was hoping that fuser might be of service, but has been fruitless thus
far. Hardware flow control is turned on in the modem, but since they modem
platform works well under the same circumstances with my Ubuntu 10.04 host
machine, I haven’t changed anything there.
the file system on my card went bad yesterday, had to reformat and reinstall Angstrom and now I’m encountering the same issue, don’t know why that worked before
My issue went away by utilizing python as my emulator instead of minicom. Somewhere in the string of terminal emulators, my CR was getting lost I think. When using pyserials miniterm.py, the comms work flawlessly.
Hi Remo, thanks for the post. I had python installed but not the tools module, so that is as far as I got with that. Turns out my issue was with getty interfering, commenting the respawn line in inittab and then restarting the init process (telinit q) got me going.
