gst-dsp is GStreamer plug-in to utilize Texas Intruments' DSP
algorithms for OMAP3 platforms (using dsp-bridge). It's used in the
official Nokia N900 system, but should work on any platform (has been
tested on beagleboard).
It's time for the next release. There have been a huge amount of
changes, mostly for stabilization, but also some new features:
* dynamic bitrate for venc
* support to force keyfrane on venc
* WMV support
* Improved H.264 decoder support
* New H.264 video encoder
* Improved venc latency
In general it seems almost ready for the 1.0 release... once the WMV3
issues have been solved, and the parsers are finalized.
Thanks to all the people that contributed to this release. Here's the shortlog:
Felipe Contreras (49):
Makefile: trivial cleanup
plugin: update ranks to primary
Trivial cleanups
base: add a few more branch prediction hints
h264enc: enable bytestream by default
h264enc: fix default bytestream mode
New skip hack
venc: cleanup some cache operations
Implement multiple parameters
venc: use a global frame_index
venc: increase number of buffers
venc: improve setcaps()
venc: enable packet-mode for H.263
venc: disable unrestricted mv for H.263
venc: set a more proper intra_frame_interval
venc: h264enc: mark keyframes
log.h: fix trivial warnings
vdec: refactor sink_setcaps a bit
get-version: trivial cleanup
vdec: trivial cleanups
dummy: trivial code-style fixes
dsp-bridge: add proc get info stuff
dsp-bridge: make dsp_node_get_attr() public
dsp-bridge: add dsp_enum_nodes()
log: generic improvements
vdec: setup h264 params
venc: add missing buffer clean for jpegenc
venc: add bitrate property
jpegenc: force ports to have only one buffer
log: reorganization for better pr_test
venc: support dynamic bitrate configuration
Makefile: add -fPIC
Trivial cleanups
{venc,vdec}: rename {send,recv}_cb
{venc,vdec}: add send_cb for output buffers
base: trivial simplification
Update code style for switches
Trivial parent_class improvements
base: add {src,sink}_event virtual methods
venc: add empty event handlers
venc: add finalize function
venc: initial 'force keyframe' support
venc: store event to push downstream
venc: add upstream 'force keyframe' support
base: safety check for buffer length
venc: add 'mode' property
venc: start using 'mode' property
venc: set rate control based on the mode
Juha Alanen (12):
Initial support for H.264 encoder
venc: add generic and h264 specific structs
venc: add bytestream property for h264
venc: add recv_buffer callback for h264
vdec: modify MPEG4 create phase parameters
base: use proper buffer length in send_buffer
vdec: modify some WMV parameters
vdec: add support for WMV3 decoding
vdec: add support for WVC1 decoding
vdec: add recv_cb for wmv
vdec: send dynamic parameters for wmv
vdec: update frame index in wmvdec_send_cb
Mark Nauwelaerts (8):
vdec: call send_cb earlier
base: make error handler helper public
vdec: add priv_data for h264 lol
vdec: add h264dec_transform_codec_data
vdec: transform h264 buffers to bytestream
vdec: cater for h264 node output parameters
vdec: add extra size checks for h264 transform
vdec: handle the case where NAL size prefix is < 3
Tim-Philipp Müller (3):
base: fix some minor but recurrent memory leaks
Fix refcount leak when setting up pad templates
base: don't leak input buffer if we have a non-OK flow return
Youness Alaoui (1):
Plugin a leak on video encoders
