gst-dsp is a GStreamer plug-in to utilize Texas Intruments' DSP
algorithms for OMAP3 platforms using the tidspbridge driver.
This is a major release, many features have been implemented:
* Huge reorganization
* Support for IPP (image post-processor)
* Support for AAC decoder
* Support for VPP (video post-processor)
* Huge optimization for video encoders
* Improvements on caps negotiation
* Improvements on H.264 keyframe generation
* Improvements on hang detection
* Memory leaks fixed
* Fixes for WMV
* H.264 encoder tuning
* Support for gtk-doc
* Fix for JPEG encoder
Again, we have a lot of contributors. Thanks to everyone!
You can download the tarball from the usual place:
http://code.google.com/p/gst-dsp/downloads/list
And here's the amazing shortlog:
Arvind Gupta (2):
base: USN socket node interface changes
vdec: initialize the frame index for WMV
Elamparithi Shanmugam (19):
ipp: scaffold element
ipp: socket-node creation
ipp: add algo initialization
base: add some vmethods
ipp: add pipe init
ipp: add pipe deinit
ipp: add buffer processing
ipp: add error handling mechanism
ipp: add dmm_buffer_begin/end
ipp: add yuv420p to yuv422i conversion
ipp: add chroma suppression
ipp: add EENF
ipp: add dynamic parameter support for eenf
ipp: add YUV420p input support
ipp: update colour format in sink capability.
ipp: overwrite input buffer
ipp: fix to exit gracefully if error occurs
ipp: check for valid height and width value
venc: use 4 output buffers
Felipe Contreras (96):
build: use newer DSP API
venc: fix bitrate caping
Fix clang warnings
bridge: fix dsp_wait_for_events() for DSP_API < 2
vdec: trivial cleanup
venc: move level fetching to setcaps()
venc: properly check for H.264 stream-format
venc: only strip sps/pps when marked as keyframe
h264enc: remove 'bytestream' property
venc: store level
venc: send max-bitrate to the sn instead of bitrate
venc: general cleanups
venc: unref caps after gst_pad_set_caps()
base: remove warning for empty buffer
build: make SN_API=2 the default
vdec: shuffle h264
vdec,venc: get rid of foo_data
vdec,venc: move profile_id selection to the args func
vdec,venc: reorganize arg_data stuff
vdec: create separate extra_data() handlers
base: introduce td_codec structure
vdec: reorganize into td_codec
venc: reorganize into td_codec
venc: fix compilation warnings
Make global gstdsp_set_codec_data_caps()
Create tidsp library, and split codecs
tidsp: generic cleanups
tidsp: h264enc: remove dead code
parse: properly update crop framesize
plugin: set a sane source package
Add gtk-doc
build: include tidsp dir on dependencies
tidsp: h.264 dec: trivial fix for I420
base: refactor ts_array/event_array
base: also use buffer durations
Rename 'id' to 'index'
base: decouple stream id from port index
vpp: add scaffold
vpp: add codec info
vpp: improve output framesize negotiation
Fix compilation warnings
tidsp: fix JPEG encoder for old SN
base: export send_buffer()
Get rid of gstdsp_send_buffer()
ipp: add vmethods' scaffolds
ipp: trivial cleanups
ipp: refactor get_yuvc_params()
ipp: add INTERNAL_FORMAT define
ipp: add support for older SN
ipp: move eenf params to ipp structure
ipp: fix the port allocation
ipp: reset semaphore correctly
ipp: fix memleak on errors
ipp: cleanup reset()
ipp: cleanup error handling
ipp: detect fatal errors
Trivial cleanup
base: trivial cleanup
base: introduce td_buffer
base: reorganize td_buffer stuff a bit
base: add port to td_buffer
base: trivial improvements in send_buffer()
Use td_buffer in {send,recv}_cb
base: use td_buffer in the queues
base: use td_buffer in send_buffer()
ipp: fix td_buffer handling
base: reorganize send_buffer()
Move 'user_data' field from dmm_buffer to td_buffer
Move 'used' field from dmm_buffer to td_buffer
Move 'keyframe' field from dmm_buffer to td_buffer
base: remove 'used' field in td_buffer
Fix gtk-doc stuff for ipp
Trivial cleanups
Add conditional compiling checks for caps_to_str
build: improve build for c99
tidsp: h264dec: trivial cleanup
Add new gst-dsp-buffer
venc: increase number of output buffers for JPEG
Add option to reuse output buffers
base: don't flush initial pinned buffer
base: don't flush last pinned buffer
base: trivial cleanup in send_buffer()
{h264,mp4v}enc: enable buffer recycling
sem: add new g_sem_down_timed()
Avoid hangs with g_sem_down_timed()
base: avoid possible leaks with pinned buffers
dmm_buffer: check for zero length on mm operations
tidsp: h264enc: move I frame interval to right place
Remove hack to manually force keyframes
tidsp: h264enc: re-add intra frame interval
tidsp: h264enc: always strip/ignore sps/pps
tidsp: mp4venc: only try to extract extra-data for MPEG-4
Trivial coverity cleanups
Juha Alanen (5):
venc: mux SPS/PPS only when in bytestream mode
venc: update H.264 encoder output parameters
vdec: fix handling of WMV codec_data in WMV3 case
vdec: update parameters for WMV
venc: decouple H.264 mode and intra-refresh
Karunesha Uh (1):
venc: add mbs per frame field in codec level tables
Lauri Lehtinen (7):
ipp: add framerate to out caps
ipp: add event handler
ipp: eenf dynamic params parsing from an event
ipp: add noise filter strength enum property
ipp: fix memleak by consuming eenf-params event
ipp: performance hooks
jpegenc: expose quality as a property
Mark Nauwelaerts (7):
base: adjust buffer allocation
base: unref caps going to READY
base: free some more buffer arrays at _stop time
vdec: specify need for complete au's in H.264
td_h264dec: do not leak transformed codec data
base: check for unexpected buffers
build: also clean in tidsp subdirectory
Miguel Verdu (5):
venc: provide correct level to H.264 encoder
venc: check level takes bitrate as target
venc: h264: tune QP value for Initial frame
gst-dsp-buffer: fix memory leak
base: remove unnecessary gst-dsp-buffer creation
Stefan Kost (2):
headers: adhear to gtk-docs weired gobject requirements
doc: fixes and improvements
Tommi Myöhänen (1):
ipp: fix EENF params parsing
Víctor Manuel Jáquez Leal (4):
vdec: remove destroy_node()
td_jpegdec: compute the correct structure size
base: add codec update_params() callback
adec: aac decoder implementation
