One question which just hit me Does anybody know if there is any good
reason why the memory is hard divided between ARM and DSP (using the MEM=xx
directive in the Linux cmdline?) In theory I think it should be possible to
do dynamic allocation from the same pool coordinating the allocation in
dsplink/dspbridge (is this i.e. supported in Syslink?).
Not 100% trivial I agree (but not impossible either I think), and it would
allow better memory utilization for people running mixed use cases instead
of always reserving xx MB for DSP usage, which are just wasted in case of no
DSP codec running?
Any good reason not to do some kind of dynamic allocation (except that it of
cause complicated things coding wise until it's stable and running or is
it simply just an old left over from the way it was initially implemented?
Best regards - Hope somebody can clarify
Søren
