Any info on Pocket beagle 2 Industrial
Does anybody have any experience with the Pocket beagle 2 Industrial and can point me to any documentation on it?
I like the extra memory and colder weather rating for not much more price wise.
Thanks!
What do you want to know?
Hope not too many questions as I have been looking before asking.
Is their any documentation that mentions it, not even at Seeed studio?
How do I use the eMMc memory?
Has anybody found any issues with it?
Any reason it is not popular considering the extra ram and cold weather operating conditions?
Any project pages that use it?
Documentation
PB2 industrial is just a PB2 with eMMC populated(64G), and upgraded parts to handle a wider temperature range. First few batches of the PB2(non industrial) were shipped with dual core processors)
Not sure what you mean. They should come preprogrammed from the factory. Just plug in using usb c cable to your machine and run ssh debian@192.168.7.2. It will ask you to change your password and close the connection. Just run that command again and then run df -h and you will see a 64GB storage device(which you are using)
debian@BeagleBone:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        56G  3.9G   50G   8% /
devtmpfs        391M     0  391M   0% /dev
tmpfs           456M     0  456M   0% /dev/shm
tmpfs           183M  812K  182M   1% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-resolved.service
/dev/mmcblk0p1  256M   36M  221M  14% /boot/firmware
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS2.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyGS0.service
tmpfs            92M  4.0K   92M   1% /run/user/1000
I’m only aware of a single issue in the past where it wouldn’t boot up correctly sometimes, but i believe that has been fixed in SW. Haven’t seen it happen for a long time. Depending on what version is on the device from the factory it may or may not have this issue, might need to run the update command or just reflash the emmc with a new image.
Its still relatively new.
Thank you very much for helping a noob on this board. It should help get me started!
As I’m still looking and found some drone usage which is what I was looking for!
I bought two of the industrial versions and the two capes.
Thanks again!!!
Go WiFi and I will double dip like usual!
I saw someone, @Juvinski primarily, get ardupilot up and going with the Pocket Beagle 2.
I am trying now but it could be a decade later before I get that up and running.
I am not too savvy with ardupilot yet nor Dronecode Foundation. Still tryin' over here...
Eould love to hear about it as you come along with it
I just purchased the Pocket Beagle 2 Industrial. I will update you on findings soon.
I am sure it is as easy as running the premade beagleboard.org script for installing the micro SD Card to eMMC. Let me see if I can find that script…
sudo beagle-flasher I am pretty sure is the script to run or the command to run to handle flashing to the eMMC from micro SD Card.
Yes the eMMC is just detected as an sD style card, it really the same thing, flash accessed over SDIO lines. The eMMC has 8 lanes, whereas sD card has only 4. If they install a fast eMMC chip, it should be very fast, as the AM62xx has the spec to do very fast sdio (something like 200MHz iirc).
Thanks for the git hub post on this project. I’m following it and looking forward to getting my back ordered boards .
