I’m unaware of anything beyond what you have already found. I’m not sure what Vivado can do, but I don’t think there is any ability of SoftConsole to do more than read in a configuration generated by the MSS Configurator.
PolarFire comes to Microchip via several mergers. My impression is that Microchip is now making an effort to make these more accessible and easier to use, but it may take some time.
With the Xilinx tools you hand off the hardware design to the software IDE, relevant drivers are then added to the project, addresses set etc. If you update the hardware design the software project also updates, it is all automagic.
I wonder where the source of the drivers for the Microchip IP is though?
There are many more ip blocks than are in this PolarFire repository, at the basics just headers for the register addresses to use with the HAL would be useful.
What I am working towards is getting AXI streaming working, to be honest as the day progressed the driver level is probably the least of my problems
Generating the ref design to use with the bare metal AXI streaming example and then programming it causes the DDR training to halt at 80%, the demo code will not start, the main() of the 51 is never called. Need to solve this, or put in an issue, maybe it is not supported on the disco board yet even though it looks like the ref design supports it.
This is all Fire related though, I want to get some AXI Streaming HLS designs ported over from Vitis HLS to run on the Fire, I think it may take some time…
I feel your pain my friend! Although I wiil probably continue to moan, at least quietly, about Vivado
or FPGA tools in general, Libero does seem to rate quite close to the bottom of the bunch,
based in part of your and my own, albeit limited, observations.
I’m happy to see you’re making progress though; strangely comforting.
In the meantime, I think I’ll be keeping to using Libero as an elaborate Gateware viewer, hehe.
It’s probably easier to just make custom designs work on a Zynq based build and then port
the code, once they validate in Vivado / Vitis.
I think you need to tie the unused inputs either high or low depending on whatever won’t generate an interrupt to the MSS. Right-click on the input pin and then select Tie High or Tie Low menu item.
-Tim
