Like many, I’m having issues with loading device tree overlays at boot.
uname -a
Linux spa.turrim 4.4.4-1-ARCH #1 Sat Mar 5 18:30:09 MST 2016 armv7l GNU/Linux
Or does it have something to do with the external RTC specifically? I made a cape that had an RTC which loads correctly at boot time using kernel 3.8 something, so maybe it’s a kernel problem. Can you check if another cape loads automatically on boot correctly?
–David
Correct, if you use an initramfs, you must copy the dtbo objects into it.
https://github.com/beagleboard/bb.org-overlays/blob/master/tools/dtbo
RobertCNelson: I am not using initramfs
After some experimentation I found a sort-of solution.
I removed the call to bone_capemgr from uEnv.txt, then decompiled /boot/dtbs/am335x-boneblack.dtb with
dtc -I dtb -O dts am335x-boneblack.dtb > am335x-boneblack.dts
then inserted the content of my overlay into am335x-boneblack.dts and recompiled with
dtc -O dtb -o am335x-boneblack.dtb -b o am335x-boneblack.dts
Now I get the RTC as I like at boot.
The question remains what’s up with bone_capemgr and /lib/firmware at boot. I’ll ask on the Arch Arm forum.
/boot/dtbs/am335x-boneblack.dtb withdtc -I dtb -O dts am335x-boneblack.dtb > am335x-boneblack.dts
recompiled withdtc -O dtb -o am335x-boneblack.dtb -b o am335x-boneblack.dts
For next time:
The question remains what's up with bone_capemgr and /lib/firmware at boot.
I'll ask on the Arch Arm forum.
btw, there was a weird bug in v4.1.x, if you didn't have "quiet" on
the /proc/cmdline, the overlay wouldn't load... could be another thing
to check..
