are there other ARMHF repos?
By default when I install a BB with one of the usual RCN builds, the repos as defined in /etc/apt/sources.list are set to the following:
deb http://httpredir.debian.org/debian/ jessie main contrib non-free
deb http://httpredir.debian.org/debian/ jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb https://deb.nodesource.com/node_0.12 jessie main
deb [arch=armhf] http://repos.rcn-ee.com/debian/ jessie main
Are there other well-known ARMHF repos that I can add if the package I’m looking for isn’t there?
For example, I like to use “fish” as my shell. When I try to install it, I get this:
$ sudo apt-get install fish
Reading package lists… Done
Building dependency tree
Package fish is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘fish’ has no installation candidate
Yes, I could build it myself, but that defeats the entire purpose of having package management, automatic updates when security fixes are available, etc.
Stéphane
deb Index of /debian jessie main contrib non-free
deb Index of /debian jessie-updates main contrib
non-free
deb [arch=armhf] Index of /debian jessie main
Are there other well-known ARMHF repos that I can add if the package I'm
looking for isn't there?
Well this is a problem. "well known" does not necessarily imply "secure".
All those listed above except for the nodesource, and RCN repo's are
official. Personally, I would not add the nodesource repo, but have no
qualms with Roberts repo.
For example, I like to use "fish" as my shell. When I try to install it,
I get this:
$ *sudo apt-get install fish*
Reading package lists... Done
Reading state information... Done
E: Package 'fish' has no installation candidate
available, etc.
So build the package once, and use it multiple times. This is one reason
why I would not use the nodesource repo. I build my own Nodejs, from source
tarballs my self. Currently I have a Nodejs 4.6.2 *deb, that I install on
any system that needs it. Just a simple file transfer, and sudo dpkg -i
<package name> away.
By the way, the package I built from source, would work on any armhf, using the same libc. Which I forget which version comes on the latest beaglebone images. but a good guide is that whichever system you want install it on uses the same version of gcc. So in this case, the package I built for my beaglebones was built on a Raspberry Pi 3 running Raspbian Jessie, with gcc 4.9.x.
The point I’m trying to make here, is that this package would, and does work for more than just the beaglebones.
try again:
sudo apt-get update ; sudo apt-get install fish
https://packages.debian.org/source/jessie-backports/fish
