In Beaglebone Black I’m trying to run a baremetal program (UART0 running in polling mode).
Using boot compiled using baremetal toolchain gcc-arm-none-eabi-10.3-2021.10 as Secound stage bootloader to load and run the baremetal program.
Uboot is compiled with config “am335x_evm_defconfig”. Copied MLO, u-boot.img from the uboot compiled to the SD-Card.
Compile the Baremetal program without vector table to run over uboot. In bare-metal program I have disabled FIQ and IRQ.
I’m try to run the application from two address both are behaving differently
Trying to load application to the RAM address 0x402f0400 from uboot - getting error “trying to overwrite reserved memory…”
$ fatload mmc 0 0x402f0400 helloworld
loading and running application from address 0x80000000 from uboot- baremetal program is running, but soon the target is restarting.
$ fatload mmc 0 0x80000000 helloworld
$ go 0x80000000
Below is the start-up code of the bare-metal application:
.globl _start
_start:
mrs r0, cpsr
bic r0, r0, #0x1F ;@ clear mode bits
orr r0, r0, #0x13 ;@ set SVC mode
orr r0, r0, #0xC0 ;@ disable FIQ and IRQ
msr cpsr, r0
mrc p15,0,r0,c1,c0,2 ;@ read cp access register
orr r0,r0,#0x00F00000 ;@ enable full access to neon/vfp (coproc 10&11)
mcr p15,0,r0,c1,c0,2 ;@ write cp access register
isb ;@ instruction synchronization barrier
mov r0,#0x40000000 ;@ switch on vfp & neon
vmsr fpexc,r0 ;@ set EN bit in fpexc
ldr sp, =0x4030CDFC ;@6kB public stack TRM 26.1.3.2, used when copying and running the program from the RAM address 0x402f0400,
//ldr sp, =0x8030CDFC ;used when copying and running the program from the RAM address 0x80000000
bl psr_main
.loop: b .loop
Below is the linker script of the baremetal program:
MEMORY
//RAM : ORIGIN = 0x80000000, LENGTH = 0x1B400 // used when copying and running the program from the RAM address 0x80000000
RAM : ORIGIN = 0x402f0400, LENGTH = 0x1B400 // used when copying and running the program from the RAM address 0x402f0400,
SECTIONS
.text :
(.text);
}> RAM
.data : { (.data); }> RAM .bss : { (.bss); }> RAM
I’m new to the bare-metal programming and Cortex-A8,
Please guide me if something is missing from my side.
Thanks.
