Hello All,
I have a issue with the access to the global memory area commom to PRU’s. I have this routine that writes and reads one memory position ; it works when I choose PRUx_DRAM = 0x0000 ( PRU0 area ) but fails when I choose PRUx_= 0x2000 ( PRU1 area ) and I don’t understand why.
It works by pressing a key and return , and it prints each time the last value + 1. When it doesn’t work the value read is allways 0.
Code listing:
* Read PRU1 shared memory and print out
* /var/lib/cloud9/BeagleBone/Green/More/MemExp
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/mman.h>
#define PRU_ADDR 0x4A300000 // Start of PRU memory Page 184 am335x TRM
#define PRU_LEN 0x10000 // Length of PRU memory
#define PRUx_DRAM 0x0000 // Offset to DRAM 0x0000 or 0x2000
//#define PRU_SHAREDMEM 0x10000 // Offset to shared memory
volatile unsigned int *pru1DRAM_32int_ptr; // Points to the start of local DRAM
int main()
unsigned int *pru; // Points to start of PRU memory.
int fd;
printf("Servo tester\n");
fd = open ("/dev/mem", O_RDWR | O_SYNC);
if (fd == -1) {
printf ("ERROR: could not open /dev/mem.\n\n");
return 1;
pru = mmap (0, PRU_LEN, PROT_READ | PROT_WRITE, MAP_SHARED, fd, PRU_ADDR);
if (pru == MAP_FAILED) {
printf ("ERROR: could not map memory.\n\n");
return 1;
close(fd);
printf ("Using /dev/mem.\n");
pru1DRAM_32int_ptr = pru + PRUx_DRAM + 0x200; // Points to 0x200 of PRU1 memory
int i = 1;
int j;
while(1)
pru1DRAM_32int_ptr[0] = i;
j = pru1DRAM_32int_ptr[0];
printf("-> %d\n", j);
i++;
if('q' == getc(stdin)) break;
if(munmap(pru, PRU_LEN))
printf("munmap failed\n");
} else {
printf("munmap succeeded\n");
