I’m trying to send some data from ARM to the PRU for the PRU to execute upon it, but I’m having some issues where it tends to miss some of the data on the PRU, so I assume I am not synchronizing the interrupts properly, here is basically what I am doing:
C code:
for (i = 0; i < 10; i++) {
prussdrv_pru_write_memory(PRUSS0_PRU0_DATARAM, SHARED_MEMORY, (unsigned int*)pkts[i], memSize);
//if I put a sleep here it generally works: usleep(500000);
//printf(“sending intc…\n”);
// here are the packets!
prussdrv_pru_send_event(ARM_PRU0_INTERRUPT);
// wait for PRU response
//printf(“waiting intc…\n”);
prussdrv_pru_wait_event (PRU_EVTOUT_0);
// clear PRU response
//printf(“clr intc from PRU0…\n”);
prussdrv_pru_clear_event (PRU_EVTOUT_0, PRU0_ARM_INTERRUPT);
PRU:
HANDLE_DATA:
// wait for interrupt
WBS r31, #30
// reset interrupt
LBCO r20, CONST_IEP, 0x44, 4 // Load CMP_STATUS register
sbco rResetInterrupt, CONST_PRUSSINTC, SICR_OFFSET, 4
// handle data
MOV R31.b0, PRU0_R31_VEC_VALID | PRU_EVTOUT_0
sub rCounter, rCounter, rCounter
qbne HANDLE_DATA, rCounter, 0
Kernel: Linux beaglebone 3.8.13-bone79 #1 SMP Tue Oct 13 20:44:55 UTC 2015 armv7l GNU/Linux
Thanks!
I'm trying to send some data from ARM to the PRU for the PRU to execute upon it,
but I'm having some issues where it tends to miss some of the data on the PRU,
what I am doing:
C code:
The ARM has a weak memory model. You need a memory fence instruction
here to insure that all writes before the fence (your write to the PRU
memory, above) have completed before any writes after the fence
(generating the PRU interrupt) take effect.
It's a bit ham-fisted, but you can use a __sync_synchronize() here
(assuming you're using gcc...it's a full memory barrier). Or you can
use the C++11 memory fence semantics (more complicated). Either is
way better than the "old school" full cache flush and invalidate!
awesome! Thank you! Do you know where I can find a good example of using shared memory? I am wondering if I might be better off using shared memory instead. Does shared memory work both ways so that ARM can access the PRU memory and PRU access the ARM memory?
There is a DDR example here: https://github.com/beagleboard/am335x_pru_package/tree/master/pru_sw/example_apps/PRU_memAccess_DDR_PRUsharedRAM
Then if you need a better explanation of the code( Like I would ). You can read this: http://www.embedded-things.com/bbb/understanding-bbb-pru-shared-memory-access/
My mistake, I think the second link I gave is an explanation of the PRU shared memory and not DDR shared memory. So, if you do a google search for “beaglebone pru shared ddr memory” there are lots of hits out there. You’re bound to find something that makes things understandable.
All of the examples are "shared memory", including the initial code
(which used shared memory and interrupts). "Shared memory" in this
case meaning memory that both the ARM core and the PRU core have
read/write access to.
If the links William provided aren't what you are looking for, be a
bit more specific about your question and it will be easier to help you.
