Armbian Support and Ideas/Just Building Blindly and Trying Here!
Hello…
I am building an Armbian build since support has been added. I was chatting online with some fellows about the process a long time ago. I have since fell off for builds with the BeagleV-Ahead.
Not much has changed in Armbian territory. Thank you!
Outside of the kudos and thanks there in text, I am building Armbian now with WSL2 and trying to port a build in /build/output/images/My_IMAGE.img and coming up short. It seems my .img file writes correctly without error but does not boot.
So, just some background:
  1. I have an image on the eMMC.
  2. The Armbian image is on micro SD Card.
  3. I fiddle away and can get the correct, already completed images to boot via micro SD Card.
So far, I cannot get a self-made image to boot properly…
I noticed that fat was the boot medium on the fs for the BBAI-64. I could be wrong but I always thought when adapting a micro SD Card for booting to beagleboard.org boards specifically, one needs to set up the formatting a bit differently. This could very well entail why it is I am having difficulty.
Anyway, any clues are welcomed.
P.S. I am building u-boot and the kernel now to get PCIe to work for Wifi on the BBAI-64 or other boards. @RobertCNelson , thank you for taking time out earlier to assist in the helping aspect to all things Linux and pointing in the right direction. Pinpointing why I am having such a rude time so far is just the icecap on these builds!
So, I was able to boot into the system with Plucky. Phew…
Anyway, I think somehow I messed up my eMMC in the process.
[ 6.490732] Buffer I/O error on dev mmcblk1, logical block 7633648, async page read
I have mmcblk0 but not the mentioned mmcblk1 for whatever reason. I think trying blkdiscard on the system ruined it… Also, I got into a initramfs system with the image from the BeagleBoard.org Imager source but could not boot to eMMC.
I think I figured out why… Off to test.
Plucky works and so does Trixie…
P.S. There is support for other boards too: Armbian Linux - BeagleBoard
and… PocketBeagle 2 - Armbian
See…oh yea.
